Project`67 Dart GT 340 A500
Junior is doing well. Not much different since last post.
This was at work the other day.
Did you add a small piece of wire across your gaps, or just a solder bridge?
Can't really say its wrong, but I probably would have laid a small jumper wire in the solder puddle. Probably the biggest thing you are fighting is making sure the copper trace on the board is really clean.
Don't know or presume to know your soldering skills, but most people grasp the heat concept, but not necessarily the cleanliness. A good clean iron tip that is pre-tinned with fresh solder is just as important as clean connections. Having anything "dirty" makes it take longer before the solder "flows" properly thereby increasing the risk of heat damage to circuit traces, glue, or components.
I did add wire to the repair (don't remember doing that). Tested all the circuits, all are good but some of the pins were loose so I carefully swedged them. Devin suggested a ground issue, I bet he is correct. I will check that out next when it isn't a billion degrees out.
I followed the manual and the original voltage limiter did not pass the bench test last night so I ordered a new one. But I think I have a NOS one stashed away still digging.
Hi Andy
By saying "grounding issue" I mean something is grounding on that electrical circuit that shouldn't. Wires rubbing through somewhere, bulkhead issues, fuse box issues etc. The circuit board 'ribbon' is probably just the weakest link.
Happy hunting, and please..... no mushroom clouds!!!
Hi Andy
Thanks and I did understand that right from your tx. I'm double checking all of that with my power probe as I go before plugging instruments back in.
I found a good deal on some wheels to try out on Junior. I am just ready for a change. They look nasty right now but it is just dirt, they should shine up pretty good for used. Center caps need removing and fixed or replaced.
It takes some scrubbing and polishing but the caps come out pretty dang good.
And I dismounted a couple to finish cleaning and wait for some new treads after Xmas probably. I looked them up and there called US Wheel Super Spokes. Made in USA.
Keep up the posts, you're giving me motivation on my 67 GT!!
Another 340 powered (727 and 8 3/4) Dart GT, my daughter has claimed as hers, so this is her behind the wheel at Woodburn dragstrip in Woodburn, Oregon.
We are getting closer on wheel tire set up.
I got new 235/60r14 and they fit great.
Cooper Cobras
Waiting on some proper I hope lug nuts.
I bought some local parts store ones and sure enough they are junk. Why I keep trying is beyond me but I hope.
I myself screwed up when I put the 8 3/4 in and noticed it is off to the left 1/2 inch total. I will move it over and give me plenty of room now.
