Copper Dart
I need help in the pulley setup for a non-power steering non-a/c small block '70 driver.
Thanks ricky :scratch:
None of the ones you listed will work for your application. You'll need a complete set of pulleys and alternator brackets from a '70 and newer small block without A/C. If you use a crank pulley from a '72 and newer, you'll need to egg out one of the mounting holes if you're using the '70-1 only balancer. Easy to do....just use a rat tail file. The replacement ones from the dealer came with a slotted hole so you could use them with either balancer.I don't know the correct pulley combination.
I have parts from; '69 small block w/p.s. and a/c
'70 slant six w/p.s no a/c
and a '74 small block manual steering with a/c
I need the set up for a '70 Dart small block no a/c and w/manual steering.
What crank pulley, water pump pulley and alternator pulley and bracket to make this work? Sorry if the question sounds dumb but I can't seem to come up with the correct arrangement. Please help.
Thanks,
ricky :banghead:
You click that big thanks button. At the buttom.how does one "thanked" one?
as soon as I can find it, I'll post them. I owe several thanks to you all.Still looking:banghead:You click that big thanks button. At the buttom.
Thanks! Good info here.
