Q's for my Fellow Mopar Brothers
63spf
DODGE'S ARE KOOL BUT PLYMOUTH'S RULE !
Kona , Hawaii
Ok, I am in the process of moving in the spring perches on my 68 Valiant Signet. I will be shortening an 8.75 rear to fit a set of N50/15s. My Q's is what gear ratio would be best with my /6 and tire size combo. With auto set up? It will be an everyday cruiser with a possible turbo added later. I have a 741 case with a 3.91 suregrip ready to run. but not sure if it's too much gear for the /6. Mahalo for the Help & any and all advice is much appreciated, C
Tried these, sbp 14s and I liked the look "BUT"
if I have to spend the time and money to move perches and shorten rear.
I might as well , Go Big or Go Home ! That was what I was always told.
Please tell me you’re keeping the slammed stance with the new wider tires.
Them are fighting words
Haha
Well, maybe not an LS, but im saying it makes sense to start in the back and build up forward
that way your replacing parts at your own pace, and not on the side of the road when they break
but between you and me, those lowering blocks are worse then an LS swap
To a true Mopar Man, nothing is worse than an LS swap.
Just remember that the further in you move the springs, the more body roll you get. Consider adding a rear sway bar, and obviously, a front one if you don't have one now
