RustOnWheels
225 slant six, Carter BBS, 1965 Plymouth Valiant station automatic.
When it’s cold and I prep the choke (one full step on gas and then a little gas, then start), it starts alright, then put it in Drive and from then on, after a few seconds - if I have it at quarter gas - it will stumble and rumble. After about thirty seconds it will get better again. But… it will always stumble a little at quarter gas.
With stumble I mean misfires and vibration. It’s warm outside now and it still does it. After a long drive it will also misfire at idle, in any gear (also P).
Now there is one thing I noticed just this evening: when I turn on my headlights it seems like the stumble and misfires at quarter gas seem to be less, the engine seems to run a little better as well. At the same time I also noticed that the gauges slowly went up after turning on the lights; the value of the temp went to perfectly in the middle in stead of a little low, and the gas gauge went a little higher.
So I suspect that I need to do something with the electrical system (voltage regulator? Alternator?). But to get it running perfectly at quarter gas I do think I need to do something more. I’ve already measured the accelerator pump height as in the workshop manual and checked the Carter as good as possible (bought it as refurbished, I believe even here), but the misfire persists with the pedal at quarter (without movement) so it seems it’s not the accelerator pump per se.
What do you think, on the voltage and the carb situation?
