Question about carbs for tunnel rams
I think that's why they give a minimum length so you got plenty to go longer...
Back again, sorry for all the posts, got a couple of newbie questions, firstly, looking at the pic i posted earlier with the tunnel ram sitting on my engine, is the top on the right way? Also can anyone please tell me the correct name of these "spacers" i have circled in the pic below?
Thanks again for the help!
The spacers are velocity stacks. The distributor can be clocked any way you want to make the vacuum can miss the intake manifold. The top is on correctly when the slope of the carb pads is down in the front. Just like you have it in the picture with the distributor. So that is correct.
Remove the distributor and ether rotate the rotor 180*’s outa d then re route the wires accordingly or move the oil pump drive with a big screw driver. With the large flat top screw driver, stick it in the pump drive as if removing the drive but just keep rotating the drive a number of teeth u til the distributor clears.
Disagreed! those spacers are called "badass!"
This is going to sound silly, but what will happen to the firing order by moving the oil pump drive?
I can't spin it 180* as the vac adv hits the firewall.
Also, is it possible to actually remove the vac adv unit all together? It doesn't get used anyway.
Moving the spot in the oil pump drive (intermediate shaft) will just move the position of the rotor a little bit. If you needed a lot of room & have the room to move the distributor 45*’s or 90*’s, the new number one spot can still be slide over a bit.
Sit down and just play with it and you’ll see what I mean.
And yes! Good lord that thing is really tight in there.
Hello all, just wondering if there's a throttle cable bracket available for these tunnel rams? Any help always appreciated thanks.
Ps. i think i have rectified the vac advance issue.
When talking about carbs cfm isnt how much air a carb will flow but how restricted the carb is. Ultimately you want the carbs that will give you the desired vacuum level at full throttle for your application.
Put a 390 cfm 2bbl on a radical 540 engine, its gonna kill a lot of power but it will still suck the cfm it needs just at a higher vacuum level "restive" .
I'd go with two 500-650 ish carbs.
Nice engine set up.
Try a Lokar cable. For a more conventional like set up where the cable pulls the carb throttle arm.
Lokar : Products
Give them a call.
LOCATION
2545 Quality Lane
Knoxville, TN 37931
CALL US
Toll Free: 1-877-469-7440
865-824-9767
Fax: 865-824-9761
MAIL US
Have a tech question or general inquiry?
tech@lokar.com
Lokar Throttle Cable Brackets SRK-4000
Lokar Hi-Tech Throttle Cables TC-1000HT
hi guys, finally fired up the engine today after fitting alloy heads and tunnel ram with the 2 x 500 Eddy's, but its idling too high, setting the timing to where it was originally makes it idle around 1200 rpm and the idle screws are out all the way, im going to have another look tomorrow to see if i can make some more adjustments, but im thinking a possible vacuum leak? Couldn't see anything obvious though. If anyone wants to throw some suggestions my way it's greatly appreciated thanks.
If your idle screws are all the way out, the carbs are to jetted to lean.
Idle to high and the timing is where you want it?
Idle screw(s) are adjusted to far in.
Double check timing, look for air leaks.
Make sure both carbs fully close at the same time. Make sure the linkage is opening and closing both carbs exactly at the same time and distance.
Thanks rumblefish, so i have found the problem! Spent quite some time looking over it, checking for vacuum leaks, resetting idle mixture screws to 1.5 turns out, looked at idle speed screws on both carbs and couldn't see any evidence of anything being wrong. So next step was to remove carbs and see if there was anything visibly wrong, removed fron carb and spent some time looking it over but couldn't see anything wrong at all with it, so onto rear carb, looking it over and came to the idle speed screw and noticed it was wound in considerably! I was like WTF??? Looking at it while on the engine it looked fine! Anyway so i wound it out til it was just touching the stopper (or whatever it's called) and re fitted the carb, hooked everything back up and started the engine up and right away i noticed it was better, so i went and set the timing and now it's all good!
Next step....dyno!
I have a question that's probably going to sound stupid but here goes....
As you can see from pics, i'm running velocity stack air filters, but i want to run these like in the pic below >>>
But my problem is these are 9 inch diameter and from what i can tell, they wont fit as thay are slightly too large. The stacks are 8.75 inch diameter see pics >>>
As you can see, i have sat a 9 inch top on one of the stacks and the difference is visible. Anyone have any suggestions as to why it wont work on mine? I would have thought all tunnel ram tops would have the same centre point to point (centre of carbs). Thanks in advance.
