Question for Ritter block users.
B3RE
B³ Racing Engines
USA
I posted this question on Moparts also, hoping to find an answer. Does anyone know where I can get the filter nipple adapter to use a standard Chevrolet filter? Supposedly, they are out there but I haven't been able to find it, and Kent doesn't know where to get them either. A remote filter is not an option in this application. Thanks.
I called and asked my machinist if he knew of the adapter and he didn't remember. He said the threads on a Chevy filter is 3/4-16 if you can match the block threads on the opposite side of the plate. He had to work on a Ritter block for a customer last year, but it was solving an oil leak. He said a Ritter block does not use an LA 340 rear main seal. It takes a different one that is an off the shelf seal, but to call Ritter to get the part number. Sorry to not be able to offer a sure fire answer.
Thanks JD. The Chevy filter is actually 13/16-16 thread, and the block is 3/4-16. The 3/4-16 filters do not have a large enough gasket diameter to fit the Ritter block, hence the need to adapt for the Chevy filter which is has a considerably larger gasket od. I took a trip to a semi-local hydraulic hose and fitting supply shop and they were able to match something that will work with some minor trimming. Appreciate the reply!:thankyou:
Systems-1 on mine. Cartridge type filter, in billet housing. The base has machined areas for large and small gaskets/rings. Mine is using the larger diameter gasket.
OIL FILTERS Archives - System 1 Filters
Yes, I saw those, but we're a bit different in application. Nice filters, though. Customer is gonna try to hide as much of the modifications as possible under the Shaker scoop.
Yeah, sure. Why not?
Thanks for the reply.
Awesome!
