Tires are everything...with a 2wd car, it is pitifully easy these days to run out of tire LONG before you run out of power. That applies to us in particular since so many of us have V8s and 15" (or smaller) wheels.
As we have talked about many times, outside of straight-line-only drag tires, there simply are no options for 15" performance tires taller than 24.5" OD (which almost all of us need for our cars).
That said, a lot of us are stuck on BFG T/As, Cooper Cobras, M/T Sportsman ST, etc. In addition to the 400+ treadwear ratings, these tires are S Speed Rated (112mph) or T speed rated (118mph), either of which is too close for comfort (IMO) for what a basic 400ish hp car would be running in the quarter.
So what's the best you've done on this cheesy class of tires? What's the best you've seen?
Would you even show up to a drag strip with these tires? Do your cosmetic all seasons give you pause when out driving like a hooligan?
