Rad offset
Dragnut
Pottstown Pa.
So why did Dodge offset the drivers side Rad support by an inch?
The radiator will be pretty much square with the fan. The drive line is shifted to a angle so the entire chassis is a little bias. The body is corrected to square. You found a spot where the correction is accomplished. One spot were they didn't correct the body is rear wheel wells. One rear tire sits closer than the other.
