j par
Long time ago I got two 12in electric fans from a member. I believe he said they came out of a 440 motorhome. Of course they work fine when I got them and then of course when I installed them one didn't LOL. No problem I just clean the contacts.
I've always just ran them off a manual power switch. They didn't like a 20 amp fuse and they seem to pull more and did fine after a 30 amp. I helped a customer install a automatic control switch for his Mustang and I went home and immediately purchased one and installed it. But I haven't hooked up the wires yet. Of course now after it's installed I start doing my research and find out it's only 20 amps.. so of course now that it's all installed I own it..
Anyways I was researching this is a little bit and someone was talking about putting it on the backside of the circuit on the ground wire? Quit possibly not taking the hint of the electricity? But you know I don't know electricity like that and it probably doesn't matter one way or the other it's just going to end up eating it up in frying the fuse. I think what I might do is I have and extra circuit going up to the front as well left over from the electric water pump. I may just split the fans up and run one manually and One automatically. I'll feel a know when the automatic one comes on. I also can go get yet another $30 actuator and mount it to the other fan?
I don't know I guess this is more of a what would you do kind of thing?
Thank you for your time and experience....
