Radiators in an A-body?
In my '72 dart, i have the original 22" radiator. I am ready to buy a new aluminum radiator. Getting one that has 1 inch tubes with 2 rows, like cold case or ECP, champion, etc..Obviously, i know i can go with another 22" and should fit no problem, but i think i would be better of going up to the 26". My question is will the 26" fit between the frame rails without having to cut into the rails? I know i would have to drill new mounting holes but thats not a big deal. I just DONT want to order the 26" only to find it wont fit in there and then have to try and send it back..I know some of the newer 1973-76 A-bodies actually came with the 26", but i dont believe the 1967-72 ever did..
Just buy a 22" Direct fit radiator from Griffin they work great. No need to go with a 26"
I cool my iron head 30 over 340 roller engine with factory A/C with a Griffin no issues
Stock water pump, hi flow stat, factory pulleys and fan
I modified a junkyard $5 shroud from a dodge truck for my 69 barracuda. They have the same offset as the a bodies. Took a little bit of trimming and improvised mounting, but looks and works fine. Not perfect, but mine is a driver, so I am not aiming for perfection.
Griffin has an 1 1/4" tube radiator. I have a 28x19 crossflow w/ those tubes in my 68 fastback, I haven't even cut the core opening wider to expose the tanks to incoming air , so their still covered . The griffins are all welded , no epox or pressed on tanks either.
I put an ECP 26" rad in my '70 Duster, I didn't look closely to see if the opening in the core support was big enough because the new rad looked to mate up fine, I doubt there's more than an inch on each side that's being covered by the core support. My old factory 22" radiator had big brackets on the side to reach the mounting holes and was visibly narrower than the opening in the core support by at least a couple inches, almost like the car was already set up to accept a wider radiator...? The ECP 26" radiator was pretty much a bolt-in btw, only had to drill an extra hole in each of the mounting brackets and another 2 for the shroud, very easy.
The core support blocking airflow will limit the cooling capacity a bit but the bigger radiator will still cool more because it has more fluid capacity and more surface area exposed to air (even if a small amount of that air isn't really flowing through the fins).
It fits in my 68 barracuda. It works. High flow water pump and 195* high flow t-stat. I wanted both input and outputs on the passenger side as ultimate plans are for a big block. I went with rubber hose for the top, and silicone hose and appropriate clamps for the bottom. I will try to remember to post up some pics tonight when I get home.
I used a wire coat hanger to plan out my hose shapes and then took it to oreilley and found the closest shape of appropriate diameter.
Griffin Performance Fit Radiators 8-70038-LS
The summit pic looks like my 28x19 crossflow. I think a guy could get a little wider in a 68 fish if he wanted to. If I ever have to buy another for this car, I`ll try a 29 or 30 , ----------probly would have to trim the frame rails pinch welds for a 30 tho.
JSD Auto G126
just fits between rails, maybe 1/2" gap ea side at most
fills the core opening, plus a bit
Holds about 1 gallon more than "stock"
your original battery tray may not fit (didnt matter for me)
iirc it was about $120.
made a simple saddle btwn the rails to support the bottom, with rubber cushioning.
nothing is bolted thru the rad, just lightly clamped in place.
72 demon 0.060 over 360 zero deck ported heads .540 solid cam
hasnt run over 195* in traffic on a 105* day without a shroud and a 10% coolant mix. (auto in neutral at lights)
About 2 years running it and I'm happy.
I have a stock F body (mopar) shroud modified to fit, but apparently do not need it, so...we'll see.
(yes, it says "chevy" on the box)
i put a 26" champion in my 68' valiant. fit between the rails just fine. there's a fair amount of bracket on each side, so even i could have trimmed it if needed. i did not cut the core either
Do you have a part number? Also how is it doing cooling it? I have a mild built 318 with headers and I live in tucson az. I want to find something that will keep it under 210 in the summer in stop and go traffic
I just put a COLD CASE 22" radiator in my 68 last night. Perfect fit with no issues and looks great too. I've used them before and haven't had any issues.
dragging this thread from the past (sorry about that) but is your radiator you show here the "MOP756A-7"? I'm looking to change my radiator in my 360 equipped '67 barracuda. Yours looks like a direct bolt in, very nice.
I do not remember the 22" Cold Case # that is in my '69 Dart, ( I can look it up), I had to go back to the cast iron water pump with a Hayden #2947 and 216 fan. I needed that 3/4".
Yeah, the cast iron water pump gives the much needed room. I bought the 22" CC radiator for my 70 Duster and the mech fan would not fit even with the Hayden 2947 clutch.
thanks, yes if you know the number that would be great. I assume your engine is stroked? How is the rad keeping up?
I currently have the aluminum High Flow Milodon pump on it (MIL-16250), so Is that longer than the cast iron pump?
The MIL-16250 looks to be the same as the newer water pumps, so it is longer than the cast iron. The cast iron also has the inlet on the driver side.
Water temps are fine. Yes, the aluminum and cast iron pumps inlets are on opposite sides. Aluminum, passenger, cast iron, drivers. My Milodon pump failed in just over a year, I now have had a Flowkooler on for about 3-4 years. The cast iron pump is 3/4" shorter.
My Cold Case is MOP756A.
I swapped to the later water pump that was 3/4 inch loner in my 69 barracuda. What a disaster. I had a cold case radiator that sits a little closer to the engine. I had to use a Hayden 2947 fan clutch. Couldn’t get bolts in it. Had to locktite studs in the water pump and use nuts. Said every swear word I know multiple times.
Coldcase makes a great product, but every 1/8 inch of clearance matters. I walked into it kind of blind because I was trying to put ac in the car with a factory compressor from a 71 dart. AC engine front end stuff is much easier to find fot 1970 & up engines. I didn’t anticipate the clearance issues with the longer water pump snout and the aftermarket radiator closer to the engine.
Yes, this radiator won't fit in my other Dart, a '72 318 with A/C. No clearance, aluminum water pump.
I ordered a 22" aluminum radiator from Jegs for my 67 Belvedere wagon with a 383. In my case it was part number #555-MOP-22B-6669. I'm sure they have 22" radiators for A bodies as well. Once painted, the rounded top tank actually looks quite close to stock, and the car runs nice and cool. The price was actually about half the price of others I had been considering.
The 26" radiator that came in my 69 fit fine. I wound up going with a 22" Aluminum Griffin radiator. It works OK, but I wish I knew then what I know now. I would have left the 26" in and cut 1.5" off each side of the radiator housing. I would have reinforced the cut on each side in a manner that would have made up for the cuts and not looked bad. More cooling area for a modified 340 is never a bad thing.
I had a brass 26" E-Body radiator with a high-performance 4 core, so I had the lower outlet moved to the passenger side to use with a stroked 5.9 in my '68 A-Body. It didn't required cutting the frame rails, but I did trim the core support to allow for more air flow, and used nut-certs for the new bolt holes.
It fits well and you can see the parts I trimmed in the photos below. The small triangular black parts were trimmed for my transmission coolers.
Thanks everyone for the great responses. Looks like I have more thinking to do. My current (non-aluminum) radiator (22 inch wide x 22 inch tall) is working fine even without a shroud but I was thinking to do an easy upgrade for the future.
