I need to replace the variable wiper switch, and hook up the linkage, so I need to remove the A/C under dash distribution box for access . How many screws to remove it? Then does it just slide out?
I'm also considering leaving it off altogether once I get it out, to allow more space under the dash for a gauge panel. There is no A/C hooked up. Does anyone have a picture of the hole that would be left if it is removed? The heater is functional, and I'm wondering if I could just fabricate a block off plate or a grill of some sort if it needs to stay open.
