replacement odometers?
500duster
Mercer PA
Does anyone offer replacement odometers for old Mopars? The odometers are froze up on both my 67 Barracuda and 67 Coronet. It causes the speedo needle to jump and the gears that turn the odometer click like crazy. I've had the odometers out numerous times , lubed them, realigned the numers and got them working but within a few miles they sieze up again. I can't see anything visually wrong but something is binding. Anyone know of a good source for repair or replacement? Or good used ones? Thanks
I think the only option is finding a used speedometer. There may be proffessional rebuilders that could rebuild yours. Maybe RedFish might be able to do it.
The odometers are a bit complicated. If the assembly isn't put together right it will hang rather than roll a digit over as it should.
I can repair them but cleaning them doesn't work. I cant make them look new without stickers/decals.
