Replacing e-brake handle
djais1801
point pleasant nj
is there a trick to removing the pin? Does the setup have to come down to change?
Thx!! 1972 demon
You might fit a piece of 4X4 between the handle and the floor, then drive the pin out. Proper method is move the assembly to the workbench.
Use a narrow punch on one side and a small socket on the other side and with a C clamp push the punch through to the socket side. After out a little bit use pliers to remove it the rest of the way.
