Retun bung
themoparman73
Sanger, CA
Hello
I was wondering if my fabo family have any pictures of there return line bung on the stock fuel tank. Thinking of adding one of these.
Thanks and happy Easter
I'm thinking I read somewhere at the top of the tank opposite the pick-up. So, front of the tank close to the bottom of the trunk floor.
Professor Fate
I was thinking the same thing, just hooking it up there straight or do the bung thing on top of the tank. or cut that nipple off and have the bung there.
Professor Fate
If your tank already has the return fitting, just use it. No need to add another bung (and introduce another point for a potential leak).
Anyway, you can't just "cut that nipple off" and add the bung there- that nipple is just the end of a line that extends another 6-8" into the tank and is internally welded in place, diverting return flow away from the float/sender.
Hello
What exactly are you doing? If you need a return line, the small one above the sending unit is too small for most any pump.
You need to weld a bung on the tank. Preferably up in the passenger side front corner.
Without knowing what you are doing we are just guessing and any advice given is a crap shoot.
