reusing head gaskets
Yes you can, I had the same problem and I called Cometic and Jason told me that they don't tell people to reuse them but he said they had reused a head gasket on a drag bike 9 times. They did spray it with copper coat, I use it also. If the coating comes off when you remove it you will have to spray them. If you spray them first they don't stick.
I had to remove one head after using it for approximately 300 miles cleaned it well and reused the cometic gasket no problem. I think I raised my torque pounds up a little bit and could feel the gasket actually continue to crush so far so good.about
two years now
Can cometic MLS head gaskets be reused? Gaskets were installed and torqued but not fired.
mine were retorqued 4 times when I built mine / measureing things . I didnt torque them to full torque untill the last tightening , which was only 5 pounds diff.
I`ve read they can be reused by quite a few people . even used to be in their advertisement ----------
My dad has re used some small black head gaskets 3 times now. Race engine motor with just under 11:1 compression and doesn't see more than 6500 rpms. No issues thus far.
