1. 73duster513
    73duster513 Member
    10
    7
    Aug 18, 2021
    Ohio
    Local Time:
    5:42 AM
    Ok question while transporting my 360 with no heads on it my ratchet strap broke going around a bend and engine rolled over and all the lifters came out on one side of the engine and scattered in the bed of the truck (lifters not damaged) can I reuse them even though I don't know what bore they came out of (hydraulic non roller lifters)
    If using the same cam
  2. 512Stroker
    512Stroker We are all here because we are not all there.
    3,272
    2618
    May 30, 2016
    Freedom, MO
    Local Time:
    4:42 AM
    Nope
    Once the lifter develops a wear pattern with its cam lobe it must remain with that lobe.
    Good luck finding any worth buying.
    • Agree Agree x 3
    • Like Like x 1
    • Thanks! Thanks! x 1
    • Disagree Disagree x 1
    • mopowers
      mopowers Well-Known Member
      6,599
      3809
      Feb 15, 2006
      West Sacramento, CA
      Local Time:
      2:42 AM
      Are there still companies around that can reface them? With the poor quality of new HFT lifters these days, I'd be tempted to go that route.
      • Agree Agree x 7
      • Bad Sport
        Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
        42,326
        28603
        Jun 12, 2010
        The Wolverine
        Local Time:
        5:42 AM
        Nope. You can install new ones and follow proper break in procedure.
      • beanhead
        beanhead Well-Known Member
        349
        420
        May 21, 2017
        wackyfornia
        Local Time:
        2:42 AM
        Call Mike @ Jones Cams. He deals only Hylift-Johnson quality lifters. Availability may be tight at the moment, like so many other things..
        • Agree Agree x 2
        • dirty white boy
          dirty white boy 50 yr old Juvenal delinquent
          1,802
          1215
          Dec 15, 2012
          stoneville n.c.
          Local Time:
          4:42 AM
          racer brown and oragon can, was like 4 bucks a lifter last i checked....
          • Agree Agree x 1
          • ch1ll
            ch1ll FABO Gold Member FABO Gold Member
            1,429
            843
            Jun 12, 2009
            Belgium,wi
            Local Time:
            4:42 AM
            Maybe have the old lifter face resurfaced.
            • Agree Agree x 3
            • Like Like x 1
            • pishta
              pishta I know I'm right....
              22,914
              12362
              Oct 13, 2004
              Tustin, CA
              Local Time:
              2:42 AM
              Place here does them for a buck a piece but they usually deal with the big mushroom lifters of SAAB and Volvo. Import place. The Sioux and B&D valve grinder machines both had optional lifter grinder attachments. Disclamier: I have run (Ford) old lifters on a new cam and even old lifters on a used cam and I didnt have an issue in my dirt poor 'clean the couch for gas money' high school days.. Must have lucked out.
              • Agree Agree x 8
              • Like Like x 2
              • 512Stroker
                3,272
                2618
                May 30, 2016
                Freedom, MO
                Local Time:
                4:42 AM
                Most of us have probably reused the wrong match of lifters "back in day"
                I believe the quality of the parts were much better back then and I dont know about you but my luck has certainly waned since then too.
                • Agree Agree x 4
                • Like Like x 1
                • 69FBCuda
                  69FBCuda I'm so confused!
                  3,588
                  2043
                  Aug 28, 2014
                  Florida
                  Local Time:
                  5:42 AM
                  Riding around in the back of a truck with the intake off i'd be a little more concerned with all the dirt blowing around back there.
                  • Like Like x 1
                  • Agree Agree x 1
                  • RustyRatRod
                    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                    85,355
                    67184
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    5:42 AM
                    Most likely, as long as they all have a good wear pattern, they'll sling back in and run fine. What I would do in that instance is lube them up good with some ZDDP camshaft lube and break them in kinda like new. High idle for a few minutes. They'll probably be fine.
                    • Agree Agree x 10
                    • Like Like x 2
                    • fishmens67
                      fishmens67 FABO Gold Member FABO Gold Member
                      12,669
                      13641
                      Nov 10, 2012
                      idaho
                      Local Time:
                      4:42 AM
                      Many times. lol
                      old cam, old hydraulic lifters who cares run it.
                      • Agree Agree x 3
                      • pomonamissel
                        pomonamissel Well-Known Member
                        2,051
                        1137
                        May 21, 2015
                        san jose , ca
                        Local Time:
                        4:42 AM
                        nope , need new one if got johnson high lift hyd lifters new in the cases . ran a leak down test on them . they all leak down after should off , ended up getting some though summit . i'll sell use some of my leak down tested one if your low bucking this engine .
                      • Ceedawg
                        Ceedawg Well-Known Member
                        564
                        352
                        Aug 2, 2016
                        Va
                        Local Time:
                        5:42 AM
                        I’ve used the same cam in 3 different engines since 1976, lifters went where ever. At one time we would stick em in order in a piece of cardboard then found it was a waste of time. This new shit could be a different story, I heard of one wiping still in the box. I have dozens and thinking of getting the tool for the valve grinding machine. 318 to 440 all the same.
                        • Like Like x 2
                        • Agree Agree x 1
                        • RustyRatRod
                          85,355
                          67184
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          5:42 AM
                          :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
                          • Agree Agree x 1
                          • SGBARRACUDA
                            SGBARRACUDA ROY FABO Gold Member Legendary Member
                            22,011
                            10528
                            Dec 7, 2006
                            PLANT CITY FL.
                            Local Time:
                            5:42 AM
                            Put them in and send it.. RRR and others beat me to it. I use to keep them separated to go back in the same hole but gave up on that one time when the box turned over and they got mixed up. Couldn't afford new so I ran um. No Problems. So since then I don't worry about same hole same lifter. I worry more about the condition of the lobe and lifter.
                            • Agree Agree x 3
                            • Like Like x 2
                            • 512Stroker
                              3,272
                              2618
                              May 30, 2016
                              Freedom, MO
                              Local Time:
                              4:42 AM
                              I too used to just mix and match lifters years ago and I do believe in the short term in mileage you can probably get away with it. Long term they will dish the lifters.
                              Op play it safe and have the lifters recrowned you will be better off in the long run.
                            • 512Stroker
                              3,272
                              2618
                              May 30, 2016
                              Freedom, MO
                              Local Time:
                              4:42 AM
                              "ran a leak down test" Interesting what method did you use?
                            • Rmoore
                              Rmoore Well-Known Member
                              661
                              517
                              Nov 14, 2018
                              Gun Barrel City, Texas
                              Local Time:
                              4:42 AM
                              Did it many times in my younger days ! Didn’t know the difference then ! Never had a problem with it though ! Probably use some of that good VR1 oil !
                              • Agree Agree x 1
                              • RustyRatRod
                                85,355
                                67184
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                5:42 AM
                                The most important time in a flat tappet lifter's life is break in. Once broken in and a wear pattern is set in, they are good to do. While it's certainly true they all do wear to their individual lobes, I wouldn't hesitate to throw them all in lubed up with ZDDP and bust it off and let it run on high idle for a few minutes. I would inspect them all first. What you're looking for is evenness of wear and none dished. If they all look acceptable, you probably won't have an issue.
                                • Agree Agree x 1
                                • MoparLeo
                                  MoparLeo NRA BENEFACTOR LEVEL LIFE MEMBER FABO Gold Member
                                  1,111
                                  806
                                  Feb 10, 2016
                                  Moreno Valley, Cal. So. Cal.
                                  Local Time:
                                  2:42 AM
                                  "probably ok" " I never had a problem, yet" " Just run em"
                                  Lots of "good, cheap advice" for the person not doing it to their car. I just wonder how many people would say the same thing if they had to pay for any damage that might happen. Just a thought. Advice is always cheap.
                                  • Agree Agree x 1
                                  • SGBARRACUDA
                                    22,011
                                    10528
                                    Dec 7, 2006
                                    PLANT CITY FL.
                                    Local Time:
                                    5:42 AM
                                    So is fear. I do what I preach. And yes sometimes I have cost myself problems with a issue. I don’t hand out advice I know nothing of.
                                    • Like Like x 3
                                    • Agree Agree x 3
                                    • 66fs
                                      66fs FABO Gold Member FABO Gold Member
                                      6,888
                                      3418
                                      Sep 9, 2009
                                      Greenwood, South Carolina
                                      Local Time:
                                      5:42 AM
                                      I used to do "cheap" rebuilds, If the lifter had a convex crown, I'd use it if it had a concave dish I'd pitch it. Never had a problem. Don't bother checking Chevy lifters, you'll never find a good one.
                                      • Agree Agree x 3
                                      • Brooks James
                                        Brooks James VET, CPT, Huey Medevac Pilot FABO Gold Member
                                        2,606
                                        1423
                                        Dec 12, 2020
                                        Fruitland Park Fl
                                        Local Time:
                                        5:42 AM
                                        Years ago i used a valve grinder to resurface lifters, worked fine
                                      • pishta
                                        22,914
                                        12362
                                        Oct 13, 2004
                                        Tustin, CA
                                        Local Time:
                                        2:42 AM
                                        Guy on Ebay chucked his GM lifters in a 1" drill press and ran them down into a piece of 220 crocus cloth on a bean bag. Said they were recrowned, ready to go! I took some solids out of a slant and they looked like telescope mirrors. I tossed the anemic stocker cam but saved the lifters for a regrind if I ever get over to Costa Mesa R&D. Great machine shop vids from these guys.
                                        • Thanks! Thanks! x 2
                                        • Like Like x 1
