RFP for the Engine Build for the Missile
Guys,
I cant say how much I REALLY appreciate this level of feedback. There are obviously some areas where I have been operating on miss information.
As far as cams go ,what about a hydraulic roller?
Andrew
NOOO. Not for the RPM you say you want to spin this build. If you can make the power you want by 6000rpm you might get away with a hyd roller,otherwise a solid is going to be your best reliable choice.
My 408 which is fairly mild in comparison with the pro charger made 667 at 5400 w/ 580 ft/lbs. forced induction is the way to go especially for a silver state race. My buddy runs a pantera there and basically runs a torque monster truck motor and with his gearing runs in the 160 mph class without rapping that motor through the roof. All depends a lot on gearing
