Rocker arm set up?
rusty
Desoto,Ks
Ok so I finally got my heads back and have a few questions.The rocker shafts have a notch in them,does that go to front or rear?What order from front of engine to rear on each side do the rockers go? I kept them in order when I cleaned them but the pushrods looked to be in weird angles so need to make sure they where right in the first place.Thank you for your help
if they are stock shafts..the notch goes down and to yours left...
driver side...notch down and toward front of car..
passenger side ....notch down and towards firewall..
are they stock rockers?,,,,,,if so there is a right and left rocker for each cylinder..
yes..pushrods are at weird angle....heads are 48 degrees..and block is at 59 degrees....
So standing looking at the engine on the side,drivers front of engine to back LR LR LR LR and passenger front to back RL RL RL RL. Or if your standing on either side of engine L will always be on you left.I know this seems like a stupid question but I think they where on wrong on the passenger side!
I ask this question because they where also at a sideways angle,please see my comment and above thanks for your help,Todd
