coronet69swede
the grey ones is CC. They are smoth as a mirror.
That grey looking shaft looks shot blasted.
Is the cam for a magnum and has no oil feed holes?
Something real wrong , viscosity is not an issue, it's lack of flow.
Second, I'd say you also have geometry issues.
how can you se that?
Because it's impossible to use a roller tipped rocker arm and NOT have the geometry be wrong. If you didn't mill the stands, order offset shafts and stands ready use a B3 correction kit, your geometry IS wrong.
There is more to it than that, but that's the short version.
I have read the B3 back and fourth. Dont really understand.
If understand correct my rocker is to long for these heads.
if i cut the stands it will center the mark but make a wider sweep.
Put on lashcap and it will make the same thing.
Moved the shaft up it made narrower sweep but further away from shaft..
I am stuck.
What is worse.
Wider sweep on center tip or
Narrower sweep of center tip
