doogievlg
I pulled my engine part last night and I found that my main bearings are smoked so this is not a huge deal but I was curious. Anybody have an idea of what may cause this?
When the scratches are uniform like that it tells me the crank grinder didn't do his job. What you are seeing is marks in the bearing from scratches on the rod throws.
After looking at your main bearings in the other thread, and seeing the surface material flaking off of them, I am inclined to think that there has been main bearing surface materials going up into the rods. It is one of 2 places where that crud would go.....
The small scratches and the dark wear area in the middle look pretty typical to me. The spots are probably the other crud from the mains. I don't see anything awful there.
The mains sure are worn out and deteriorated.... that looked unusually poor.
See if you can relate which main and its bearings fed to this rod bearing. A lot of something was coming up into this rod bearing. That's pretty nasty looking.
didnt you recently rebuild that?
yep, very easily. heck, a clogged oil passage or even a restricted one can cause it.Motor was rebuilt in 2013. Could something as simple as oil pump failure cause this?
I did not have an oil pressure gauge on the car but I cut the filter open and found the metal then threw a oil pressure gauge on it right away.
I’ll be installing a permanent oil pressure gauge when the engine goes back in.
The engine will be going to a different machinest for sure. I double checked every tolerance in the short block and everything looked dead on.
I'll ask the question.........every thing looked dead on "what"?? Do you have a list of the clearances you measured?
Did this thing detonate much? How long was it in service? It doesn't look like it was running happy!
when u hooked up the pressure gage what did she say? was everything super clean before assembly
did u wash the block and crank
Bearings are 4 years old, and maybe 2000 miles and they look like that!!!! You've got some basic fundamental issues going on. I will guess ( I could be wrong ) a start at improper clearances, ie too tight. They may have been right on the money as listed in the manual and the manual probably spec'ed out clearances in the range of .0005 to .0025, anything in that range would be "right on the money" and that's not a bad thing depending on intended purpose; Grandma going to the store, OR stand on it once and a while, entertain yourself, go to the track and stand on it. Grandma would be happy at .001 even .0015 clearance; stand on it thrill at .0015 clearance and the crank most likely will bite the bearings, .0025 to .003 would be better. I learned this one over a decade ago on a 360 I had put together, it ran about a 1/2 hour total wasn't bearing failure it was something else but I had to tear the engine completely down and found every bearing marked up ( should have kept them for garage art ). In trying to learn what happened and why, an acquaintance looked at them and stated the clearance was too tight ( I had them at .0017 to .0022 ) and he then said "loose don't break", I took my crank back to grinder and had .001 taken off, I carry 20 psi hot idle and 75 when I'm into it, std pump, hp spring, Shell Rotella 15/45.
What exactly is a fundamental issue? Took the car to the track three times and highest I shifted was 6200 rpm. 9 passes
I'm just saying that in 4 years, approximately 2000 miles ( average 500 miles a year ), 9 trips down the track and bearings look like they do, something very basic from the beginning was not right, and at this point it's all wild speculation. If you're building another engine, I hope it turns out better than this one; good luck.
Time to think about that stroker build now...
