Ironmike
Wondering what the max side clearance is. I think I might be a tide "wide". Have .022, snugged, not torqued.
Extra splash, run it.
let's hear what the crank end play is.
Depending on what rods and so forth you're playing with, you might try switching them around and maybe get some or most a lil tighter.
Connecting rod side clearance ain't critical.
You and Rusty both ALWAYS Crack me up. Simple and right to the point. I never believed that side clearance has anything to do with oil pressure. BUT, was worried about noise or some weird harmonics.Exactly. You could have .060 and you wouldn't know it. Neither would the rest of the engine. Oil flow though the rods is controlled by bearing clearance and the viscosity of the oil.
NOTHING ELSE.
Run that biotch.
I know what you mean, but others might not and might assume "tighter than a knats ***" is ok for clearance.Connecting rod side clearance ain't critical.
Yeah. You Guys are right. Called my machinist today and he said if ya have .010, you're good. Don't worry if it's wide.
Believe me, everything done. I've said it before but I got lucky and found a genius a few years ago.[/QUOTE
It's good you found a machinist who you get along with. That's almost as important as his ability to do machine work. And his trustworthiness.
