Cope
Fusing with fire
Im kicking around ideas as to hook up my roll control and 2 stage rev limit.
Do folks tie them to one wire? Part of me thinks i want both to trip with one micro switch. My thought was a switch under the brake peddle, so as soon as I let off the brake the limiter goes to stage 2 and line lock lets go.. Well i guess with line lock i wont be using the brake at stageing?..so I guess that leaves the stearing wheel button or shifter button...
How do you folks have yours set up and how (where,in the water box or at the light?) are you using them?
Thanks again.
Thanks again.
