I seen it a few times. On the quick, Comp Cams uses it. It serves more of a warning that the design is for a larger lifter since the rate of lift becomes more radical when you take advantage of the bigger lifter diameter.
Then there is the 1 inch diameter lifter and the mushroom lifter. You’ll find these in the back pages of the catalog in the race section.
