Mopar Al
MOPAR AL
I just built this run stand and wanted to share pics. Now the question is does anybody have a wiring diagram? Want to use Tach, Oil pressure, Temp. Need to know wiring for ignition, Etc. Thanks, Al.
did you use an alternator?I just ran mine mounted to the K frame on a cart.Wiring pretty simple I have a harness made up that I can send you with a universal key switch.
All you will need is the ballast - ecu - starter relay - battery cables.I didn't use any but I would just use mechanical temp and oil gages which I may have some of those around also
i will be running mine for around 20 minutes. just long enough to break it in. i want to make sure all is well before pulling the 360.You shouldn't need to have to bother hooking one up as you could run a battery charger if you planned on running it for any real length of time aside from break in. A good strong battery will go far in this situation.
idk , just a question. ive never ran an engine outside the car before. i wasnt sure if it needed to be there to complete the wiring
Phista, can this be done with an electronic distributor without the EI box wired up ?That is cool! temp, oil and tach. Run points and its a 1 wire hookup, power to coil! You wont burn it running it for 20 minutes...put it through a light switch so you can break it and kill the motor. Check this guy out, he states (4:40) "..its in pretty good shape, EXCEPT it has a Chrysler 225 slant motor in it..." C'mon! "Not too good on the gearbox but I bet it has loads of power...." http://www.youtube.com/watch?feature=player_detailpage&v=eQ5yRXiEIwg
I couldnt find the Aussie that had a V8 motor w/trans running on the floor of his garage and it was rolling around when he revved it.....
Beautiful engine stand Al!
I believe that 67dart273 has a thread or 2 that shows how he has wired up an engine for a temporary purpose. Sorry I will try and find the thread when I get a chance.
Wiring up the temp, and oil gauges should be straight forward as you will be wiring from the gauge to the respective sending unit. When I bought my auto meter gauges it was pretty easy.
Nice Stand!
will this set-up work like this . the ECU mounted on the engine block with the ground from the battery.
hmm , thanks Del, it looks like the hei would be a much more simple way to go. its not that i want to use a ballast, more in the fact that i have a 5 pin ECU box, a pigtail , and a ballast laying around. i was trying to find an easy way out using what i have
