BillGrissom
I spent too many hours last weekend removing rust from front inner fenders. They were out of the car on the ground, with easy to access every spot except a few recesses and inner corners. I actually had 2 pairs of the larger ones (in trunk when bought, none installed), so figured why not clean them all.
I don't own a sand-blaster and wonder how it compares at this task and the hours I already spent in the engine bay and trunk. I used a simple wire brush on an electric drill (various sizes). The wire brush removes rust fairly quickly, but still takes a long time for a large area. Any loose undercoating, I pick off with a putty knive, then brush a bit more away to insure shiny metal under the rest. If it pops off easy, there is always rust beneath. In some areas, I can't get to shiny metal. What is left is a hard "black rust". I keep working a spot until no more rust dust comes off and/or the metal starts getting hot.
My questions are what are the pros and cons of a sand-blaster. From FABO postings, it sounds like its main use is to get into tight areas where a wire wheel can't go. For those spots, I first scrape with a screwdriver, then put sand-paper under the screwdriver, but can never get as clean as the open areas.
Questions:
In open, accessible areas:
1. Does a sand-blaster remove rust faster than a wire wheel? If so, how big of an air compressor do you need? I know it doesn't go as fast as painting with a sprayer, but does it go as fast as say a touchup gun or is it more like painting with an air brush, in terms of covering area fast?
2. Does a sand-blaster remove rust more thoroughly? Does it get into pits better and make them shiny? Can one do as good using Naval Jelly after a good wire brushing?
In tight recessed areas:
3. Does a sand-blaster clean as well as in the open? If you blast in a small cavity does the air-stream stagnate and stop working as well? Does it get too dusty to see the work?
4. How deep can you get into crevices with a sand-blaster? How close does the tip need to be to the surface to still work? Can you get into the front bottom trench in a Dart's front door where they love to rust? Does the sand build up and make it hard to paint well after blasting?
5. How messy is the sand? Do you need to move the car outside, preferably where your lawn could use a little sand?
6. How much sand do you use and the cost? It sounds like ~$8 per 100 lb bag, and that will do maybe 1 wheel well. I read that Black Diamond sand is the best at cutting without over-heating sheet metal. It sounds like soda is mainly good for removing paint without scratching. Some use regular concrete sand or "play sand", which is cheaper.
7. How much storage space is needed for the typical Harbor Freight sand-blaster setup, and can you leave the sand in the bin ready to go? Neglect the air compressor since I need that anyway.
8. Finally, what protective equiment do you use? Has anyone read of health problems? I imagine the rust becomes more airborne with a sand blaster than a wire wheel. Rust doesn't concern me since that is what makes your blood red (and clay soil red), but there can be other metal alloys in the dust and paint that aren't so good (Pb, Ti, Cd, Cr, Tn).
For those with experience blasting, thank for any info and any additional tips. I am sure many on FABO have the same questions. We all must put on the de-rusters hat on our projects.
Questions:
