Swapping out points for electronic in a 273 commando .
Will any Small block distributor work or are some better than others?
I am looking to get one out a a 73 318.
If it's in good shape, it should work OK
Some rambling from the mess of my pile of unknown distributors:
I keep hearing that the current shelf of "Mopar Performance" dist's are not "what they were" in quality.
Someone on here with an aftermarket, for get which replacement, was having problems finding a new vacuum advance
Generally, newer factory distributors have less than favorable advance curves, and you'll want to check yours. Because the smoggers of the '70's ran at zero or ATC at idle, they and LONG, SLOW advance curves. If you try and speed some of 'em up by putting in weaker springs, some advance further than you'd like.
You'll want to at least make sure the bushings are not too sloppy, and check the reluctor gap with a "non metallic" gauge, .008"
So far as a module, I decided to experiment, and am at the moment "going with" the GM HEI module instead of a Mopar ECU.
