Scat 4” cast crank?
mbaird
mbaird
Boise, Id
Any opinions on scat cast crank for hot daily driver ?
Installing a 46rh install my Barracuda and while out I pulled the rear main cap to install new main seal . The bearings looked a bit iffy so I decided to replace them. Then I got thinking I should just get a 4” crank since I already have a set of .030 over Icon stroker pistons.
Whats opinions on a cheap Scat 4” crank to replace the magnum 5.9 crank ? Want to use stock rods, flex plate and balancer .
Anything else I need to address ?
It will need ballanced, and if it's done correctly, will require heavy metal to ballance internally. Probably cost as much as the crank did
BTW … engine has IMM ported heads , 1.7 Harland Sharp rockers , Dougs 1 5/8 headers , air gap and Oregon Cams 221/229 555 lift on a 112 cam
If they are flat top with no dish, you will have way to much compression
I run the same piston on my Swingers 408 with closed chamber W2 race heads . I will do the math but I can always use a Cometic gasket to make it right and hopefully keep my quench under .050
Just something to double check
Get hold of @PROSTOCKTOM and get some Molnar parts. Good stuff and you're supporting a member.
This car is a summer daily ( when Im not riding my dual sport or using the truck for camping/dirtbiking) and will seldom see over 5k rpm . No need for a max performance crank . I figure 450 hp maybe 500 ft-lbs.
A Callies or Carrillo would be more toward that. Molnar would be what I'd consider perfect for what you want. I'd leave a Scat crank wherever it's layin.
Running 525+ on my other 408 forged scat up to 7k. Still together .
Have at it. I see about a 200 buck difference for the Molnar piece, which I consider a superior piece. I know which way I'd go. You are asking for advice. I wish you well.
Add up the cost of what you have in the engine and ask yourself if the cost difference between a cast Scat crank and a 4340 Molnar steel crank are to much if that Scat crank breaks.
Building a short block is like building a house. You only get one chance to build the foundation correctly. If you do it wrong it will cost you monetarily and in extreme frustration.
To each their own though. :BangHead:
Tom
Last I looked he was at 900+ but that may have been forged .
There was a problem with one of the cast steel cranks breaking. A lot. I don't remember if it was the Scat or the Eagle. It was one or the other.
I used the Scat cast crank and I beam rods with Icon +0.040’’ in my stroker.
Got it all as a kit assembly.
All the parts are very good quality, all the clearances were spot on.
Can I use my stock balancer. rods will get bushed unless the cost adds up to new $.
Again .. this is not a race engine . I rarely go wide open in this car .
And that's really the rub. Cast or forged, good machine work, good parts and proper assembly are what's important.
The assembled kit I got was internally balanced, so I had to use a 318-340 balancer. Not the 360 balancer.
You’ll need to check if the stroker crank is internally or externally balanced. That will dictate which balancer you use.
