Shank Mag Lug Nut Length?
banzaibullitt
Minnesota
I have a set of older AMR S200 Daisy Mags. What is the correct mag lug shank length I should buy... .5 or .55? I know that they should not bottom out on the hub. I do not know how thick the lug washers usually are either.
Measure them, is the only way I know. I cannot imagine that a bit shorter will hurt, as long as they pilot. Make darn sure that they the wheels DO WANT shank type and not coned/ countersunk
The wheels measure out at .5 inch thick at the lug hole, and they require the shank style lugs. Does anyone know how thick the lug washers usually are?
I have tho old one piece daisies too. Washers are1/8". Buy the 1/2" shank, and double check that they don't stick out past the hub (they shouldnt).
I would measure the wheels and buy the correct lug not needed. (diameter, length, and thread size) You may have a hard time finding the right ones for those old wheels.
