Shank Mag Lug Nut Length?
banzaibullitt
Minnesota
I have a set of older AMR S200 Daisy Mags. What is the correct mag lug shank length I should buy... .5 or .55? I know that they should not bottom out on the hub. I do not know how thick the lug washers usually are either.
Measure them, is the only way I know. I cannot imagine that a bit shorter will hurt, as long as they pilot. Make darn sure that they the wheels DO WANT shank type and not coned/ countersunk
The wheels measure out at .5 inch thick at the lug hole, and they require the shank style lugs. Does anyone know how thick the lug washers usually are?
Also consider the studs...........
I would measure the wheels and buy the correct lug not needed. (diameter, length, and thread size) You may have a hard time finding the right ones for those old wheels.
