Shaved Heads/Intake
Fuel and Air Systems
  1. CowBoyRoy81
    CowBoyRoy81 Active Member
    28
    7
    Jul 3, 2014
    Marshall, WA
    Local Time:
    8:11 AM
    Quick question and I already did some searching for the answer.
    I have 360 with heads shaved .040 and the intake is a pain to get on. Going to take the intake off to inspect lifters and measure actual pushrod length. Since it'll be off does anyone know how much I should shave my intake manifold to compensate for the heads being milled that much?
    Mines the closer one. Thanks in advance!
  2. CowBoyRoy81
    28
    7
    Jul 3, 2014
    Marshall, WA
    Local Time:
    8:11 AM
    According to wallaceracing.com calculator it's .056 on the intake side. Does this sound right? to anyone? Like most people, I"m in a town with primarily Chevy and Ford experienced shops.
    • Disagree Disagree x 1
    • pishta
      pishta I know I'm right....
      13,924
      3624
      Oct 13, 2004
      Tustin, CA
      Local Time:
      8:11 AM
      • Agree Agree x 5
      • 66fs
        66fs Well-Known Member
        3,736
        672
        Sep 9, 2009
        Greenwood, South Carolina
        Local Time:
        11:11 AM
        As Pishta said above, .038 per side per Chrysler Racing Manual. They should have cut the intake side of the heads instead of Dorking up an intake.
        • Agree Agree x 6
        • 69_340_GTS
          69_340_GTS Well-Known Member
          3,118
          1080
          Jul 11, 2014
          Torrington, CT
          Local Time:
          11:11 AM
          .040" off the head block surface, take 95% of that off the head intake surface, or .038"
        • CowBoyRoy81
          28
          7
          Jul 3, 2014
          Marshall, WA
          Local Time:
          8:11 AM
          Yeah I'm going to pull the heads after all and measure CC while I'm at it. I agree they should have but when I had them done I was young and 21 and trusted all professional shops to do the right thing. Then I left for the Army and the car sat some 13 years before I tore back into it. Now I'm correcting mistakes made back then....but she's running good after a new short block and fuel system. I'm just continually improving and going to use the winter to rebuild suspension, measure and get correct pushrods, spec out the engine and service the tranny after I rebuilt it and she's now broke in.
        • 66fs
          3,736
          672
          Sep 9, 2009
          Local Time:
          11:11 AM
          Sounds good, It took me a while to find people who really knew what they were talking about. I amazes me how know-nothings can sound good and yet have no clue... Unfortunately you have to check everything if you want anything done right.
          • Agree Agree x 3
          • pishta
            13,924
            3624
            Oct 13, 2004
            Tustin, CA
            Local Time:
            8:11 AM
            yes, measure twice, ask 6 people their opinions, then cut once.
          • 70aarcuda
            70aarcuda Master Hoader of SBM FABO Gold Member
            14,086
            2148
            Jan 16, 2005
            las vegas
            Local Time:
            8:11 AM
            how thick are the intake gaskets are you using
            • Agree Agree x 1
            • AJ/FormS
              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
              15,272
              4388
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              10:11 AM
              Exactly
              if the originals were .020 and the new are .060 that would not require any cutting at all.
            • 7e5hangten360
              7e5hangten360 semi-pro
              87
              6
              Jun 24, 2011
              montreal, qc, canada
              Local Time:
              11:11 AM
              i think it is the opposite. you need to remove material not add some.
              the easy way to solve that problem would be to elongate the bolt holes in the intake, although port alignment would still not be totally perfect.
              also, i wouldnt change the pushrod length for only a .040 cut on the heads. the hydraulic lifters will have slightly more preload.
            • AJ/FormS
              15,272
              4388
              Jan 19, 2014
              Local Time:
              10:11 AM
              .020 plus zero = .020.
              .060 less .040 cut = .020
            • 7e5hangten360
              87
              6
              Jun 24, 2011
              Local Time:
              11:11 AM
              the discussion was about intake gaskets.
              if you are talking about head gaskets, i agree with you.
            • AJ/FormS
              15,272
              4388
              Jan 19, 2014
              Local Time:
              10:11 AM
              Doh busted. IDK what I was thinkin
            • sireland67
              sireland67 Well-Known Member
              7,657
              1685
              Oct 27, 2010
              WV
              Local Time:
              11:11 AM
              Also keep in mind most likely both the head and intake gaskets were the metal shim style from the factory.
              So you need to adjust for what ever thickness gasket you are now using.
              I had a rough time getting the bolts in an aluminum intake when changing from a 2 bbl, with no head cutting, or removing the heads, the only difference was the metal vs fel-pro gasket.
