Shop must haves
You MUST have a decent sound system for tunnage and I would suggest a Large smart screen TV to watch "how to" videos on.
Sometimes I wish I had an old laptop in the garage for those how to videos. I have one of those giant Sony ghetto blaster stereos with separate speakers and a sub. Its great.
I don't have a TV or a computer in my garage, but I have an 8 speaker surround sound audio system. More than a few times my wife has come out to tell me to turn it down.
I get this from my GF sometimes, who says the shop system will make me hard(er) of hearing.
Thinks I to myself, maybe so but that's what bigger amps are for. :thumbsup:
I had my speakers screwed to the walls until my neighbors complained about the bass.
They are now suspended from the ceiling. Problem solved.
I’ll just use a couple amazon echos- cheap and easy to replace. This is what we use in my office and I’ve had no problems for 3.5 years.
@halfafish what kind of shop door did you install on your new build?
I think I’ll need some roll up doors, not really sure, but I haven’t found any decently priced on marketplace lately.
For doors, I have this 48" sliding barn door for the pass-through from the old shop to the new workroom.
From the workroom to the outside I got a coil rollup like you see at storage units. The only thing I'd change on it is to spec it with an internal sliding latch. This came with one on the outside which is OK but I want it on the inside and will swap it out when I source the parts. I will also get a latch for each side.
Last suggestion before I sign out to go take a pitchfork to the ****-show in the shop. Looking at your plan for where to put the lifts - I think your placement is good. I'd put the 4-post in the front right corner and the 2-post in the front left corner. That way you can park one car up, another under, and another behind on the right. You will be getting more cars, yes? :poke:
Two more cars can go on the left. Plus you keep the pull-through , a very nice perk. Driving under and through a 4-post can have unintended consequences - best to leave it on the right. Don't ask me how I know this...
Here is a shot of my shop from the back wall toward the door with the lift at the door. Once I get done rearranging (a MAJOR endeavor) the lift will go further in toward the back wall.
I figured it was a roll up door, I haven’t found a good one yet, I’d like insulated ones but I’m not sure I can get them quick enough.
The way I planned was 2 post on left to be able to pull through easier and 4 on right, but I can see by having them at the front I could use the back of the shop as a workshop type area.
I thought of putting the lifts towards the front but thought if I had them in the front they would make it harder to pull more cars in if one was on the lift.
I had a thought for an exterior air hose.
Cut a hole in the wall 18x18 or what ever is needed for the hose reel.
Mount the hose reel half way in and out.
Then build a 5 sided box big enough to have 2-4" of ridged foam insulation on the inside.
Get spring hinges like on an interior garage door to keep it closed.
Add soft playable seal material, maybe like a refrigerator door.
The warm air inside the shop will keep the moisture in the hose from freezing and keep the hose flexible.
That just gave me an idea....
Get an old mini fridge and put it in the opening with the back cut out.
You could add a rebar grid across the back to keep larger critters from getting in
Sorry for the pictures in the dark, all the lights are down in the shop.
2x10s being used for the new trusses, they were originally 2x6s. They look massive compared to the old ones.
Then the plywood is delivered and will go up on the walls after.
Shop is looking 2x as big already! He’s going to frame the garage doors next week and pick a couple up. Then he will get the electrical moved, to have enough 220 plugs. One for welder, one for compressor, one for mini split and then 2 for the lifts. Also waiting on the spray foam quote, which is what we will probably do for easy quick and done.
Planning stages of my shop I had about 1 year to figure all those important things out. 16’ to eaves gave me enough room to build a mezzanine. Mezzanine houses all my parts.
My paint booth unfinished is wired for fans and lights plumed for the sprayer it’s 16x26’. The engine area and all metal working tools are under mezzanine as well that area is 26x28 along with full bathroom that still needs finishing.
The air compressor is under stairs and I ran 1” copper around entire shop with drops by all roll up doors and along walls. Shop has separate 220 meter. Welding outlets also by roll up doors and lifts. Also every 8’ or so is outlets for whatever else I need
Spray foam entire shop covered with T-11 for easy removal if I want to add anything else.
I have a separate shop that I ran 4” pipe from 1 shop to the other for air lines if I needed and extra power if needed. There’s nothing I would do differently except go wider my shop is 42x96 was supposed to be 50x 96 but with was complaining . I put brighter lights under mezzanine easier to see. View attachment 1716494889View attachment 1716494890View attachment 1716494891View attachment 1716494893View attachment 1716494892
That is past being a shop, that is heaven.
