Slant 6 engine ignition timing stays retarded.
dodgemahal
Illinois
I'm tuning the slant in my 1973 Dart. I did all the usual stuff---- plugged the distributor vacuum hose after disconnecting. Set idle at 750 rpm. Adjusted mixture to highest vacuum @ 18" with a rock steady needle.
With the distributor rotated all the way counter-clockwise (confined by the slot), the best I can get is 5 degrees ATDC. It runs like a turd. With the vacuum advance reconnected it runs much better of course, but I can tell something isn't quite right. I've been racking my brains for days but can't solve this. I considered lenghtening the slot. I figured it's time to ask the guys who know way more than I do. Thank you.
5 deg Atdc is retarded, you want to have it 0 to 5 to 10 Btdc so it's advanced. If you are trying to set it per factory spec (67 dart 273 with CAP calls for 5 Atdc) it will probably run like a turd.
0 = 5 advanced over factory
5 = 10 advanced over factory
I typically run 0 to 5 advanced as the CAP dist has a very aggressive advance curve in the lower RPM and vacuum range.
It is about the same as the non CAP after about 1500 to 2000 rpm
I did not explain this very well. Your first paragraph is exactly what I'm looking for. I want 3-5 degrees advanced(BTDC) to begin with. I may modify that later. Factory spec happens to be 0 degrees. The problem is I can't advance the timing past 5 degrees retarded(ATDC) even rotating the distributor as far as it will go. Oh, I can retard it to infinity if I want. That's the issue.
What does CAP mean? Clean air something? How do I know? It did come with OSAC, but I disconnected that.
What is preventing you from rotating the dist?
You should have enough clearance to rotate it 15 deg in either direction
Because the screw that fastens the distributor down is confined in a metal slot. I've got it as far as it will go. As I said in my original post, I was thinking about lengthening the slot so I can go further. Would you like a picture?
What is CAP?
Might have to pull the distribtor and rotate it one tooth. Also, there is a second adjustment slot on the back side of the distribtor.
What is CAP
Yes please post photos.
CAP is Cleaner Air Package. It was Chryslers attempt to add emissions controls to their engines
I have tried clocking the distributor by one tooth already. That gets it way, way off the mark. Good idea though.
Is the plastic driven gear on the bottom of the distributor worn out? Pretty common on /6s with a lot of miles on them.
I'll look for that second slot though I can't imagine what it would look like. Can you be more specific? I've had this dist out many times in the last several months and don't remember seeing something like that.
Turn distributor upside down so the drive pinion is pointing toward you. Notice how the distributor hold-down plate is held to the underside of the distributor body with a bolt. Notice how that bolt goes through a slot rather than a round hole. There you are.
Also, if you're getting significant vacuum advance at idle, your settings aren't where they should be, but that will likely self-correct once the base ignition timing is where it should be; because it is too retarded, you will have had to open the throttle wider to achieve the 750 rpm idle speed, which will have uncovered the vacuum advance port.
Spec in '73 is TDC, but you'll have a much better-running car, without creating new problems, if you'll use the 1960s spec of 2.5° BTDC. Even better still if you will bypass the OSAC valve (right side of firewall on the engine side) and just run the hose directly from the carburetor to the distributor.
Also-also, make sure both of the distributor's O-rings are present and in good condition; info here.
Also-also-also, tune-up parts and technique suggestions are in this post and Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
You can see the screw is pegged against the end of the slot. The other end is jammed against the block. Read: NO wiggle room. I'm glad to know there's another adjustment point. Great info Dan!
Won't solve your intital timing adjustment problem, but you might want to check to see that the mechanical advace is also working next time you take the distribtor out. Made a big difference in the way mine runs.
I know my mechanical advance is okay. Right now I'm just focused on getting my initial timing sorted out.
FYI
On the small block Ds the reluctor is made universal by having two avalable slots, one for CW rotation and the other for CCW rotation. I can't imagine the six-vane slanty being machined like that, but I suppose looking wouldn't hurt.
And
Since that unit looks brand new, who knows if the roll-pin is correctly clocked.
Btw
nice camera shot in post 15
FYI
And
Btw
There's only one slot therefore only one position to clock it. I've had it in and out multiple times over the last two months doing cleaning and maintenance. I had a bad pu coil in there and Rock Auto sucked by sending me two bad ones(two different brands. Long story). I ended up buying a nice NOS unit off ebay that works. So yeah, it's the original dist. Thanks, I got lucky on that shot, haha.
You were correct SIX. It didn't work......it moved the dist in the wrong direction. Back to square one. No one else has had this happen? Thanks.
If BOTH slots are at full advance and the timing is still retarded
AND, the balancer is correctly calibrated to TDC, and the cam is correctly timed;
Then
I don't see any way past having to reclock the Reluctor.
There are at least three ways to do this;
1) machine a new slot in the reluctor, or
2) move the nylon drive gear
3) move the advance cam on the driveshaft.
#2 is by far the easiest
I had to do that on my last Slanty project. My advice is to have a spare gear on hand lol.
Then
That's certainly food for thought, albeit a somewhat unpalatable set of options.
I don't see a damper(at least not my concept of a damper) on my slant. No place to put a timing tape. I have a group of pulleys. Is that the damper?
Since this is a change, compare the new to the old. In particular the distance from the mounting stud to the pickup center. Can't tell you why there might be a difference but there's only a few parts that could change the signal relative to the rotor tip and cap.
