So a mechanic tries plumbing......
Shop, Garage and Tools
  1. pishta
    pishta I know I'm right....
    21,413
    10790
    Oct 13, 2004
    Tustin, CA
    Local Time:
    6:50 AM
    Sink in bathroom clogged like a mofo. 3 snakes down and 2 1/4" snakes almost stuck in there, barely got them out but ruined the tips as they almost unwound when trying to free them to get them out. 3rd was a 3/8 snake from my other neighbor with 4 girls so he has a big one with a drill on it. Got that down there and that one hit same thing and got stuck, started to wind up. Good thing is the clog is only about 5 feet away and is over the tub branch so its not affecting the tub, but Im gonna have to cut this cast 2" shit out and PVC it. The clean out is above the tub from the roof so the snake goes right past the branch that is plugged and there is no vent opening for the sink branch. Took freaking rocks out of the stub that the trap is connected to and had to remove that stub as the threads were shot. Took a jack to get the pipe loosened! Bummer
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    51,552
    20550
    Oct 14, 2010
    Idaho
    Local Time:
    6:50 AM
    I don' know what to tell you. I CAN STILL SMELL the "oakum" when Grampa was leading the cast pipes, I was maybe 5 years old. HUGE gas fired lead pot
  3. pishta
    21,413
    10790
    Oct 13, 2004
    Tustin, CA
    Local Time:
    6:50 AM
    F'n A....
    • Like Like x 6
    • clementine
      clementine Flight risk FABO Gold Member
      1,862
      1327
      Jan 3, 2016
      Emerald city
      Local Time:
      6:50 AM
      Seems like you even touch that old type pipe you have to deal with other parts of it. I say cut....not twist. get some kind of union that uses a rubber compression ring.
      • Agree Agree x 2
      • Joey4speed
        Joey4speed FABO Gold Member FABO Gold Member
        1,618
        1319
        Jul 17, 2018
        Coastal NC
        Local Time:
        9:50 AM
        Yep, "no hub" fittings, mate Cast and PCV easily.
        • Agree Agree x 3
        • Like Like x 1
        • Dana67Dart
          Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
          7,893
          5491
          Jul 16, 2017
          Northern Colorado
          Local Time:
          7:50 AM
          That rocks!
        • 67dartgtgo
          67dartgtgo FABO Gold Member FABO Gold Member
          1,484
          929
          Nov 9, 2012
          Mass
          Local Time:
          9:50 AM
          I’ve had luck using a good shop wetvac sealed at the top of the drain and tapping the cast with a hammer at the clog. If you can free it up at all some of it should come free enough to be sucked back up. Good luck.
          • Like Like x 1
          • WTruo
            WTruo Well-Known Member
            750
            915
            Jan 1, 2020
            West Texas, ya'll
            Local Time:
            8:50 AM
            Thats actually kinda brilliant.
          • Mike69cuda
            Mike69cuda 66 is the new 17 FABO Gold Member
            2,560
            2095
            Jan 2, 2018
            Overland Park Kansas
            Local Time:
            8:50 AM
            Ever used a Drain King? Works great in some situations. It is a inflatable rubber bladder you put on the end of a garden hose. Put it down the drain, turn water on & it expands to seal the pipe. Will blow clogs out. However, It will also blow up traps and other weak spots in your plumbing.
            • Like Like x 1
            • pishta
              21,413
              10790
              Oct 13, 2004
              Tustin, CA
              Local Time:
              6:50 AM
              Neither will work on this bad boy as there is a vent stack right above it. All the pressure will go up and out. Vent stack terminates in wall. Gonna cut and assess tomorrow. Done the rubber band clamp before, not scared to use it again. Cant get the "little buddy" bladder as there is a hard 90 right where I need to get down into. I have one and it does work great in the clean out at the base of my kitchen, straight shot under the kitchen from the outside.
            • Mike69cuda
              2,560
              2095
              Jan 2, 2018
              Local Time:
              8:50 AM
              Yep, tried that. Thought I had the drain cleared with one till I noticed it was raining outside on a sunny day. Water was coming out the roof stack & down over the kitchen window.
              • Like Like x 1
              • famous bob
                famous bob mopar misfit
                19,857
                8844
                Aug 14, 2011
                okla
                Local Time:
                8:50 AM
