bigtommy
old school power
i am looking to put a cam in my 318 and was wondering which cam would be best. a solid lifter cam or hydraulic lifter cam?
I like solids in a small cube motor.
its a 1975 rv motor. im looking for a street car. but would like to take it down the track once in a while. and do i need to get adjustable rockers or will the stock ones work.? i was looking at this soild cam. http://www.summitracing.com/parts/CCA-20-246-4/
or for a Hydraulic cam i was looking at this one http://www.summitracing.com/parts/CCA-20-212-2/
You'll get more out of it with a roller cam either solid or hyd (I have a full hyd roller setup in my 340).
To bad the roller is triple the price and not part of the choices listed. Then the expense of the rollers, there's a fat amount of cash, ugh!
Worth it if your going "THERE" no doubt.
ain't that the truth. I'd love to have put a roller cam in my new 408 but just couldn't afford it.
now is the "roller" part just the lifter or is the cam roller too? what rolls on it because i know the lifter has a roller on the end.
since you give no other info except it is a 318..i would use a comp 262 hydraulic cam...and the matching 901-16 springs...
