Hi
I am looking for solid roller lifters that are optimal performance vs price in your experience!
Cam spec is:
263/[email protected]", 108+4, 675/675 lift
Springs planned for this will be 720 open and 260 seat there will be nitrous added so its on the high side.
Block is not bushed so my 1st guess was 829-16 comp, I know they are not oil pressure fed but in my view its weak spring what kills these lifters, when someone runs this kind of cam on the street, he beats on it anyway. I never used oil fed lifters ;-)
This said, I talked to Howards and they recommended their oil pressure fed 91735 race max lifters which are bit more expensive than comp, I was also looking at Crower 66233 lifters that have oversized wheel non pressure fed lifters...
There is also BAM lifter which is pressure fed and has oversized wheel pn 2016-16. Also Lunati lifter seems to be recommended by them for all solid cams they have and its pn 72421 and this is the most affordale of all, but it looks like Morel 4730 which is not recommended by Morel for the spring pressure I want.
So I narrowed it down to:
Lunati 72421 440$
Comp 829 606$
Howards 91735 677$
Crower 722$
BAM 835$
I'm also worried that pressure fed lifter will take some of the idle in gear oil pressure which is down because of HS rockers already, just between 25 and 30lbs on my mechanical gauge. What are your experiences with this?
HELP
Cam spec is:
Lunati 72421 440$
Comp 829 606$
Howards 91735 677$
Crower 722$
BAM 835$
HELP
