There is no inner wheel bearing in a 7 1/4 rear end unless you want to call the carrier bearings an axle bearing but it really isn't. You'd have to pull the rear end apart to change those. When you pull the axles, grab the axle bearing with one hand and rotate the axle with the other. If you feel any kind of hitch at all or hear any noise, the bearing needs to be replaced.
I sure will cudamark :happy10::rock:
I have the drum on backwards and have been slowly moving it out with a hammer, I called Creed and told him his big sliding hammer is not in his box.
enough for to day, I did the run test with out the drums on and the driverside did not move, I could barely move it by hand, I went to the passenger side and stopped the axle with my foot and put a long pry bar on it so it would not turn, The drivers side was squeaking and I could hear it smooth out then start squeaking again :happy10:
Enough of this for today
Time to get a axle puler our a sliding hammer before I hurt myself or something ells :-D
Some one take a close look at my brakes, looks like the drivers side is on wrong, or is the passengers side wrong, I can look that up :read2:
thanks to abodyjoe :cheers:
What side is correct, small shoe in the back or front ?
