Spark plug advice
HemiDenny
HDK Suspension
NW Ohio
What is a good plug to start with for a 408?....10:1 compression. Lumpy (don't know specs) hydraulic cam.
Might be over carburated....thinking 750 cm Eldelbrock.
Thanks in advance for any input.
Denny
I use Autolite 3924 on my heads,
What are the heads you are using?
Cast / steel heads. Look like a factory head. I bartered for the engine, owner bought the car for the body and a 528 Hemi install ...so he knows less about it than I do.
Cast / steel heads
I run Champions in my Mopar's . Just sayin. I know there are probably better quality plugs out there ( like maybe NGK or Bosch) but I don't like the heat ranges they build. If you do try a non-Champ plug make a run and pull a couple plugs to read how they are burning. I reduced compression on my freshly built 273 and tried a Autolite plug. I had a rough/rich idle issue and come to find out the plug was a heat range colder than the original N9Y Champions. I bumped up a couple heat ranges and all is well.
Obviously plug preferences are like asking what oil is best to use, but just for kicks I’ll tell you I run NGK in everything.
My 9.5 compression Magnum has had NGK GR5’s set at .050 in it for 5 years or more and they have been flawless.
(Thinking to put new ones in anyway):D
I am running a Holley Street Avenger 770 that performs great in all ranges, and I know for fact a 750 isn’t overkill on a 408.
In fact my own opinion is that a 408 could use all of an 850.
BTW, one of our local Mopars4us group picked up one of your K members, A arms and power rack and pinion setup.
Impressive stuff.
Denny
i'm using champions on my 426 stroker no problems 7,000 miles and the plugs look fine , cheap and they work
Stock heat range or one step colder.
How much timing you can run can impact choice.
THIS!!!! ^^^^^^^^^^^^^^^^
100% all day long everyday!
100% dead on bulls eye. No doubt about it.
Choice of plug is your call. I run Champs without issue.
RN12YC, is, IIRC, the Edelbrock-recommended plug for my alloy heads.
If I told you that I installed them at .045, in my 367, in 1999, would you believe me?
How about if I said they currently have over 100,000 miles on them?
I use a big Yellow Square-top Accell SuperCoil. In a pinch, I think you could weld with it. lol. I have not looked at the plugs since winter of 2004/05.
EDIT; see post #12
thanks for your input. just looking for a decent place to start and thought I would ask the experts.
Yup. I agree on the Champions and what hooha said in post #6. That'll probably get you right on the money.
If it’s an Edelbrock or other aluminum head it will be an RC12YC and not the N series. The 13/16 hex won’t fit in there.
EDIT: the OP says he has iron heads so he can use the N series plug.
Denny
Denny I have never been a fan of Champion plugs it always seem like I could never get the heat range correct. For the past 5 years I have found that Autolite 64's work well in my warmed up 10.5:1 iron head 345 SBM. I also ran Autolite 63's in in my 512 stroker B body - no issues.
Cheap and all the parts houses have them available.
Good luck
This might be a stupid question but how do you know the heat range I'm looking at the champion 405 copper plus plugs I dont see a heat range in the description
What is the number designation of the plug? 405 is the stock number.
You should be looking at an RC12YC or equivalent IIRC your engine.
R = resistor
C = plug type (3/4 reach, 5/8 hex is a C)
12 = heat range
Y = tip length
C = copper core
The C and the N series Champions are the exact same plug EXCEPT the N series is a 13/16 hex and the C is a 5/8 hex.
I’m not a fan of the 13/16 hex. I was hoping that Champion will kill the N series plugs and keep some others they have evidently killed.
R = resistor
12 = heat range
Y = tip length
C = copper core
Rn14yc is what the 405 are so does the heat range go up or down based on the number? Would 14 be a higher (hotter) heat range than the 12?
R = resistor
12 = heat range
Y = tip length
C = copper core
I learn something new literally every time I visit this forum. Love it.
Higher number, hotter plug with Champion plugs. NGK is the other way. The bigger number is colder.
I would do everything I could to use a a C series so you don’t have the dreaded 13/16 hex. And I’ll tell you why.
Because as much as I say use the C series, when I went into town Wednesday to grab some plugs and other junk to fire the 340 thats on my run in stand, and they only had N series plugs in the heat range I need.
The headers I’m using to fire this pig I’ve used since 1980, so I figured WTH they will be fine.
They go in there, but they are a PITA. I guess when I was younger it didn’t matter, but fighting that bigger socket just pisses me off.
That will be the LAST time I ever buy that dinosaur plug. If they don’t have the C series I’ll either order them, or if I need them in a hurry I’ll use Autolite’s or AC’s.
I now officially HATE the N series plugs to death.
Just an FYI.
I forget how the autolite plug works with there heat range stuff
