spark plugs in eddy heads
farmer260
73 Dart Sport
Fredericton NB Canada
I have Bosch +4 spark plugs for a stock LA318 will these work with my 360 edelbrock heads? the pistons i am useing will be makeing 10.5:1 compresion with these heads.
If you go to the Auot Parts store and ask for OE plugs, then ask for a cross ref. to the smaller socket size, you'll be good.
(You can see I can't remember tha plug size, but thats what I do.
Cooler heat ranges shouldnt be used any cooler than 2 steps at max! You'll be hard pressed to find gains after that unless your at a track.
I'm using Champions RC12YC5 gapped at .050. I use a MSD6AL ignition. If you are needing a .035 gap, use the RC12YC plug.
