SPEEDOMETER TESTING
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
I want to test my rally speedometer with a drill. Can anyone tell me what direction the speedo cable rotates if you are looking straight at the back of the speedo.
Thanks
Awesome! Thanks guys, I didn't want to damage it turning it the wrong way.
Don't think you can damage it by running it backwards. Backing up rotates the speedo backwards.
Makes sense. But, I wasn't sure, and this is the place to get the right info. Thanks again everyone.
If you look at the input and turn by hand you'll see its a worrm gear. The worm drives the odo and can do so either direction.
It also spins the open shell. magnets turn the drum which is restrained (calibrated) with a tiny clockspring right behind the dial.
Even though its non electrical, I posted there 'cause most instrumentation discussions seem to end up there.
Speedometer evaluation?
Mine had a little sideplay in the input shell. very gently checked with a dial indicator.
And a lot in the drum (.020").
