72ScampTramp
Scamp Tramp
I have some C body spool mounts that may need the rubbers changed im guessing these are a press out and press back in kinda deal? Also they didnt come with hardware will Grade 8 be ok?
The aftermarket replacement isolators are junk (as are ALL parts store mounts these days), but they are available in poly. For the parts store mounts you need to bend the outer shell to clear the bracket when you press it out. The poly mounts replace just the rubber and steel tube.
