starter ID
Rapid Robert
Lincoln Nebraska
having starter to a swapped different ex manifold clearance issue. I under stand that the super compact mini starter from a 2007 dodge ram with a 5.7L MANUAL TRANS is what I need. how do I ID it so I can make sure the yard is selling me the right one? thank you for your time.
Pretty much any mini starter will work
slant six dan was saying that it has to be from a manual trans, that that app is super compact more than a regular mini. I am using a different ex manifold & I need the extra clearance. EDIT a coaxial starter, the drive axis is the same as the motor axis
Correct, the coaxial starter has to come from a manual-trans truck, and it is much more compact than the usual mini-starter. Find pics of the correct starter here and here; details on what makes this starter different to the regular mini-starter here, and multi-view pics of the starter (and E-Z availability if you just want done with it) here.
