It's an aftermarket replacement for the factory rubber/nylon seal.That dont look right for an early A it should look more like a seal.
That may be true but this is the correct one.It's an aftermarket replacement for the factory rubber/nylon seal.
Correct, no bearing goes there on early A bodys, just a dust seal.That may be true but this is the correct one.
https://www.ebay.com/itm/62-63-64-65-66-B-Body-63-64-65-66-A-Body-Steering-Column-End-Seal-NEW/401207764882?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D52885%26meid%3D58cfaf3b7f6742888b3599712154f6e1%26pid%3D100005%26rk%3D2%26rkt%3D10%26mehot%3Dlo%26sd%3D362256411543%26itm%3D401207764882&_trksid=p2047675.c100005.m1851
The bearing is a better solution than the flimsy factory seal!Thanks. I know its not original. My seal was missing so when I did a search it seemed this was what was recommended. At a cost of $8.50 I thought I would give it a try.
That bearing may bind. you would have 3 bearings in line on your steering shaft: Upper, your middle and the steering gear bearing. IIRC the A-body shaft sort of wobbles in the tube lock to lock as the coupler is not a U-joint, hence the pliable (?) construction of the OEM. You may be able to get away with it but thats what I noticed when I made a straight shaft to my offset steering gear.
I got mine jacked over too !cool, your mileage may vary. I wonder of the early A's had a different shaft angle. I had my steering gear offset 1/2 inch for header clearance.
Wouldn`t a flexable coupling flex just the same on a non wobbling shaft ? It would here in the states !---LOLMy 1964 Dart just has the rubber seal with the hard plastic bushing. Be careful this modification does not make the whole steering column "too perfect", because the lower end of the shaft actually needs a small degree of "wobbliness" to enable the steering flexible coupling to function... The rubber seals have been a bit hard to get hold of until recently (I'm in Australia) and I have seen guys using those universal (stretch-on) CV Joint boots, with the small end stretched over a short piece of electrical PVC conduit, works just fine! Might not win Top Authentic at Pebble Beach...
I didn't think that particular snap ring bearing worked on the early A cars because the shaft is only 3/4 and then the late A's went to a 1" steering shaft. But I have been mistaken before.
Mobarracuda, great writeup on the ‘67 steering column rebuild!
This is true ^^^^^^^^^^^^^^^^^^^^^^^^ u can feel the diff. ~!The bearing is a better solution than the flimsy factory seal!
