Steering column wiring
armyofchuckness
The Flying Valiant
Gainesville, FL
welp, I was trying to disassemble my steering column in my 64 Valiant automatic because I'm switching to a power steering shaft instead of a manual and I wanted to paint it while I was at it. Long story short, I broke the clip for the electrical on the lower end of the column trying to back the wires out of the bracket. Anyone have a replacement one lying around? I'll be happy to pay and/or trade out an early A manual shaft for it.
Also, does anyone know the right way to get the wiring harness in and out of the column without destroying it?
Thanks!
You talking about the TS switch I assume? Not familiar with that connector but most of those you can release the terminals, pull them out of the connector, and snake it out. Tie one of 'em to a fish wire
There was a bank of seven wires coming out near the base of the column in a little brick shaped connector clip. I tried backing them out but they metal on the first one snapped immediately.
There's a special tool used to remove those connectors - found it on eBay from a guy selling a lot of Mopar-specific removal tools. I'll take a look and see if I have a spare connector although it might still have wires attached.
