DRENO
Need some help. I probably shouldn't have done this because i don'y know what the hell I'm doing,but I'm sick and tired of running from fixing my car because I don't know. Fluid leaks out my the pump in a day of sitting,can't see underneath to find a leak so I took it out.I have the .94 style on my 340.Is there a common place for it to leak.How would I check for leaks.There is 1 compression fitting,that is my only guess.Can I use teflon tape on the threads? Sounds like I don't know what I am doing,doesn't it? :banghead:
p.s. didn't realize the bolt that goes into the block goes thru to the water jacket. :banghead:
