steering shaft help.
New Hemi Engine Swaps
  1. mcat
    mcat Well-Known Member
    280
    15
    Jun 28, 2009
    cincinnati ohio 45251
    Local Time:
    11:58 AM
    i am getting my ass kicked getting my shaft to clear the valve cover.
    i have everything not necessary cut off all the way flush to the firewall.
    can i get some pics of what other people have?
    thanks...
  2. Joe Dokes
    Joe Dokes Well-Known Member
    1,131
    99
    Apr 21, 2011
    Long Beach Ca
    Local Time:
    9:58 AM
    What mounts are you using? What year A-Body. I BELIEVE (Not entirely sure) that fitting a Gen III Hemi into an early A is more difficult.
    Post some pics, I'd like to see the interference.
    Regards,
    Joe Dokes
  3. mcat
    280
    15
    Jun 28, 2009
    Local Time:
    11:58 AM
    i have a 68 barracuda, i have a hemidenny k member. i made my mounts.
    the engine is set in the middle of as high as it will go, and as low as it will go. and is centered left to right. i have the motor about 3/8 higher on the left to try to help clear. some of my issue is that i have 09 eagle heads,on an 06 block, they are taller.
    i do think i have it figured out now...i hope!
  4. Joe Dokes
    1,131
    99
    Apr 21, 2011
    Long Beach Ca
    Local Time:
    9:58 AM
    I "Believe" that the motor needs to offset towards the passenger side approximately 1.5"
    This article over at Big Block Dart has a good explanation. I do know that even though these new Hemis are only 345 Cubic Inches, they are quite wide which makes slipping them into an A-Body a bit of a challenge.
    http://www.bigblockdart.com/techpages/tips.shtml
    Hope it helps,
    Regards,
    Joe Dokes
  5. mcat
    280
    15
    Jun 28, 2009
    Local Time:
    11:58 AM
    there is only about 3/4 inch between head and inner fender, no way will it move 1.5"
    and if it is not centered, the alternator will not fit..
  6. Riddler
    Riddler Project EH-Body
    2,732
    379
    Sep 13, 2009
    Windsor, ON, Canada
    Local Time:
    11:58 AM
    Talk to Denny but yes the motor needs to be offset to the passenger side about an inch. The alternator fits once you cut the pinch weld and grind the frame rail down. This must be a car engine. Some people have converted to Jeep 6.1L alternator mount as well to help with the clearence.
    I'll try and find more info and post it tonight.
    Riddler
    EDIT - Links.
    http://www.forabodiesonly.com/mopar/showthread.php?t=202231&highlight=alternator+frame
    http://www.forabodiesonly.com/mopar/showthread.php?t=200438&highlight=alternator+frame
    Picture of the cutting:
    [​IMG]
  7. mcat
    280
    15
    Jun 28, 2009
    Local Time:
    11:58 AM
    im pretty sure an extra $35 universal in the steering shaft will save a lot of cutting and notching to make a GENIII fit in an a body and the engine will be centered too.
  8. replicaracer43
    replicaracer43 Old school member
    3,820
    2280
    Oct 10, 2008
    Local Time:
    11:58 AM
    Sounds like you answered your own question.....
  9. Riddler
    2,732
    379
    Sep 13, 2009
    Windsor, ON, Canada
    Local Time:
    11:58 AM
    ... and made up your mind as to how your going to do it.
    Riddler
  10. mcat
    280
    15
    Jun 28, 2009
    Local Time:
    11:58 AM
    yea, i think i got it figured out now.
  11. 72BBSwinger
    72BBSwinger Well-Known Member
    2,045
    53
    Feb 23, 2011
    nebraska
    Local Time:
    11:58 AM
    So now you're off center in the trans tunnel too. Or are you gonna just bolt it up to the stock trans mount for a cockeyed setup?
  12. RedFish
    RedFish Well-Known Member
    23,046
    1999
    Sep 5, 2007
    Local Time:
    11:58 AM
    The drive line is supposed to be offset to the right.
  13. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,443
    1290
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:58 AM
    ...............The rear is offset also, ur drive shaft will be running at quite a sideways angle .........kim........
  14. FJ5
    FJ5 Well-Known Member
    1,168
    49
    Feb 14, 2013
    chickasha, Ok
    Local Time:
    11:58 AM
    I'm glad I decided against this swap. Too many headaches as it is.
  15. RedFish
    23,046
    1999
    Sep 5, 2007
    Local Time:
    11:58 AM
    The rear offset isn't the same factor. That is a wheel base stagger for thrust angle. Rear offset in drive line offset would be like Ford and others have one axle shorter than the other where the engine is centered in the bay.
    Any drive line offset is related to the life of universal joints as much as anything else no matter what it is, power takeoffs included.
  16. 72BBSwinger
    2,045
    53
    Feb 23, 2011
    nebraska
    Local Time:
    11:58 AM
    The trans tunnel is offset to the right, I'm well aware of this, so with the engine centered nice and neat in the engine bay he has effectively screwed himself with the rest of the drivetrain. Maybe you guys missed my sarcasm in my first comment. He is fighting his steering column because he is centering the engine.
  17. mcat
    280
    15
    Jun 28, 2009
    Local Time:
    11:58 AM
    your sarcasm was picked up...
    obviously you have this entire swap thing figured out.. good for you.
    making a new trans mount is still easier than all the other cutting/welding required to offset.
  18. mcat
    280
    15
    Jun 28, 2009
    Local Time:
    11:58 AM
    ok fella's for those of you interested, when i got my hemi denny kframe, i met Denny to pick it up. that is where my issue started. while Denny was going over the install , he told me the motor gets offset to the left 1.5, yes he said left... he followed that up by saying that will let the alternator clear the frame rail. so the entire time i was mocking up MMounts there was no way it was going to the left 1.5.
    the trans was bolted in place, and to the motor,so i was satisfied with just getting it centered. now the mounts are finished and welded in place, the left rear corner of the VC hits the steering shaft.
    being so focused on the steering shaft, i never even thought of the trans.
    well come to find out that moving the motor to the left to get it centered in front, that cocked the trans . after taking out the trans mount bolts, the trans relcated itself to the right. that moved the back of the motor to the right. that let the VC clear the shaft.. now the motor is centered in the engine bay the trans is setting right of center. but everything fits, everything clears. and the drive shaft wont hit anything, and the universal will make up the offset in the drive line..
    now i just have to mod the trans cross member...
  19. RedFish
    23,046
    1999
    Sep 5, 2007
    Local Time:
    11:58 AM
    Those who have put this engine setup in stock K members have notched that frame rail or relocated the alternator. I don't know why a aftermarket K would make a difference in drive line angle.
  20. mcat
    280
    15
    Jun 28, 2009
    Local Time:
    11:58 AM
    i am pretty sure Denny made an honest mistake. and who was i to argue!
    now i know...
  21. Uhcoog1
    Uhcoog1 Well-Known Member
    889
    24
    Feb 7, 2011
    Houston
    Local Time:
    11:58 AM
    These suckers are a tight fit. On my swap, at this very moment, the steering shaft is touching the valve cover bolt rubber, the other valve cover is touching the passenger side fender (trimmed down the valve cover and clearance the inner fender), and the alternator is touching the fender (though the frame rail next to the alternator is GTG), and the #1 header tube is sitting on the Borgeson box.
    Once the TTI v. Borgeson issue is fixed, I'll go back to having ~sub 1/4" clearance at all points.
    Point being, these things fit very tight, with little to no room for error when positioning the motor. They're significantly wider than an LA motor.
