Stock 318 2 Barrel Cam Choice
Small Block Mopar Engine
  1. shittyslant6
    shittyslant6 Well-Known Member
    979
    1093
    Jan 25, 2021
    California
    Local Time:
    9:42 AM
    So I recently bought a bone stock '73 318 2 barrel.
    Since it is going to need to beat up on some stock mustangs from my high school, I am going to do a cam swap and put on a '71 340 4 barrel intake I got with the engine. My question is; since I am only changing the cam and intake, what cam would be best in terms of power and rump rump factor.
    I was thinking about one of these three, but I want to see what you guys suggest.
    COMP Cams K20-671-4: Comp Cams Nostalgia Plus Camshafts - JEGS High Performance
    DODGE COMP Cams K20-247-4 COMP Cams Magnum Solid Cam and Lifter Kits | Summit Racing
    Edelbrock 7177: Performer RPM Camshaft Kit for Small Block Chrysler - JEGS High Performance
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    77,883
    55742
    Jun 7, 2010
    Georgia
    Local Time:
    12:42 PM
    Only the cam? Stay with stock. A cam needs to have the correct valve springs for it and if you're not willing to do that, it's a useless proposition. So leave it stock.
    • Agree Agree x 2
    • eekvonzipper
      eekvonzipper My Member is Legendary! FABO Gold Member
      704
      560
      Apr 18, 2020
      Cadet, Missouri
      Local Time:
      11:42 AM
      The Kits He listed have the Springs Lifters and and a Chain Set Triple R...
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      20,389
      7256
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      11:42 AM
      Way to much cam for a stock street 318. Even if u installed them 8* advanced. U will need to up the compression. U would need at least a 3500 stall and 3.91s to take advantage of it. Kim
      • Like Like x 1
      • Agree Agree x 1
      • krazykuda
        krazykuda Well-Known Member FABO Gold Member How-To Section Editor
        59,761
        25910
        Aug 20, 2007
        Orland Park, IL
        Local Time:
        11:42 AM
        • Agree Agree x 3
        • Thanks! Thanks! x 1
        • 66jim
          66jim Well-Known Member
          606
          584
          Dec 11, 2007
          NE PA ie pennsyltucky
          Local Time:
          12:42 PM
          Find a cam with no more than 210@.050 intake. Maybe a replacement 360 2 bbl or similar. If you go roughly 10 degrees more duration you won't lose bottom end power.
        • YY1
          YY1 Well-Known Member
          8,140
          3819
          Oct 11, 2011
          FL
          Local Time:
          12:42 PM
          Comp XE 256?
          Summit K6900?
          POPCORN and ring side seats.....
          • Agree Agree x 1
          • 318willrun
            318willrun Utube channel 318willrun
            17,696
            20317
            Sep 13, 2013
            I'm here
            Local Time:
            11:42 AM
            • Thanks! Thanks! x 2
            • jas0162
              jas0162 Well-Known Member
              604
              416
              Apr 23, 2014
              kansas
              Local Time:
              11:42 AM
              I would run the stock cam or something close if it is worn out. You don’t want to over do it and make it a pig with no torque on the bottom. Been there done that.
              • Agree Agree x 1
              • Disagree Disagree x 1
              • 318willrun
                17,696
                20317
                Sep 13, 2013
                I'm here
                Local Time:
                11:42 AM
                i have to ask.... what mustangs are you going after ???? You might need more than just a 4bbl/cam...
                • Agree Agree x 1
                • teringer
                  teringer Well-Known Member
                  915
                  242
                  Feb 22, 2011
                  kenly nc
                  Local Time:
                  11:42 AM
                  imo all the cams are wrong /unless you have a clutch / stick with a 340( stock) cam it would be the largest to use
                • toolmanmike
                  toolmanmike Moderator Staff Member FABO Gold Member
                  61,526
                  50144
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  11:42 AM
                  • Like Like x 2
                  • 12many
                    12many Well-Known Member
                    2,201
                    2630
                    Dec 14, 2016
                    SC
                    Local Time:
                    11:42 AM
                    If say a 1974 Mustang II, it won’t be a problem I’m thinking!
                  • 318willrun
                    17,696
                    20317
                    Sep 13, 2013
                    I'm here
                    Local Time:
                    11:42 AM
                    It's written in present, so I'm thinking if he's shooting for a Coyote, he would have better luck in the woods with a .22 :D
                    • Like Like x 3
                    • toolmanmike
                      61,526
                      50144
                      Jan 18, 2006
                      Iowa
                      Local Time:
                      11:42 AM
                      COMP Cams 20-221-3 COMP Cams Xtreme Energy Camshafts | Summit Racing
                      (XE256H-10) 212/218 256/268 .447/.455 110° 1000-5200
                      I like the splits for stock exhaust manifolds.
                      Here's one in a 318. It has a nice little lope and in this vid it's in a stock 318-2. The car owner took the video after cam break in but before he installed the 901 springs that came in the kit. He said the 901's took away some of the lope at idle and also it really runs nice after installing a 4 barrel.
                      • Like Like x 2
                      • 1966Post
                        1966Post Well-Known Member
                        286
                        103
                        Mar 8, 2015
                        Wisconsin
                        Local Time:
                        11:42 AM
                        Edelbrock Performer Plus nice small bump in lift and short duration. Good torque cam
                        .420 204@.050
                        • Agree Agree x 1
                        • Killer6
                          Killer6 Well-Known Member
                          2,823
                          988
                          Mar 9, 2015
                          PA
                          Local Time:
                          11:42 AM
                          Exactly what type of "stock Mustangs" are We talking about?
                        • eekvonzipper
                          704
                          560
                          Apr 18, 2020
                          Cadet, Missouri
                          Local Time:
                          11:42 AM
                          I agree with this post, Lol
                          • Agree Agree x 2
                          • shittyslant6
                            979
                            1093
                            Jan 25, 2021
                            California
                            Local Time:
                            9:42 AM
                            the crap little sn95's of the 90s.
                          • shittyslant6
                            979
                            1093
                            Jan 25, 2021
                            California
                            Local Time:
                            9:42 AM
                            and one dipshit in his new 2019 4 banger mustang his parents bought.
                          • shittyslant6
                            979
                            1093
                            Jan 25, 2021
                            California
                            Local Time:
                            9:42 AM
                            Yeah, that one sounds good, decent lope, and could be pretty wicked with open headers.:D
                            Just wanted something that'll wake it up a little bit, was probably getting a little greedy with the .508 lift purple cam I was looking at.
                            • Like Like x 1
                            • shittyslant6
                              979
                              1093
                              Jan 25, 2021
                              California
                              Local Time:
                              9:42 AM
                              I like that .464/.464 cam, since it'll never really see the high side of 5600.
                              Thanks for the suggestions!
                              • Agree Agree x 1
                              • mopowers
                                mopowers Well-Known Member
                                5,930
                                3098
                                Feb 15, 2006
                                West Sacramento, CA
                                Local Time:
                                9:42 AM
                                Do you intend to keep the non-adjustable stock stamped rocker arms? If so, a solid cam is off the table.
                              • shittyslant6
                                979
                                1093
                                Jan 25, 2021
                                California
                                Local Time:
                                9:42 AM
                                Well now that you mention it no, i will not be having a solid cam. The best option now is the cam KrazyKuda suggested, a comp .464/.464 268/276 hydraulic flat tappet cam.
                              • RustyRatRod
                                77,883
                                55742
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                12:42 PM
                                That cam for a stock 318 is "a bit" big.
                                • Agree Agree x 2
