I met him, Karl, last year in Carlisle. I think..I've met Karl, that aint' him! LOL
How are you going to grab onto the flywheel? The bolts are too small. Stay on the crank and clockwise if you can. (so the bolt stays tight.)hmmm I'm wondering on this 383, if itd be a better idea to try to turn it over after soaking for 2 weeks in ATF by the flywheel versus the front of crank.
yeah that'd work if I had a crank bolt lol.How are you going to grab onto the flywheel? The bolts are too small. Stay on the crank and clockwise if you can. (so the bolt stays tight.)
You will need one sooner or later. The only other way is to take the flywheel off, screw in a couple grade 8's and use a pry bar between them.yeah that'd work if I had a crank bolt lol.
Good idea in theory for turning a engine over bit not a long enough handle for breaking a stuck engine loose. You can take odd teeth is you pull too hard with one of those.
flywheels are cheapGood idea in theory for turning a engine over bit not a long enough handle for breaking a stuck engine loose. You can take odd teeth is you pull too hard with one of those.
Thats actually what I was gonna do. I need to find one or maybe just go get a grade 8 one for the front of the crank.You will need one sooner or later. The only other way is to take the flywheel off, screw in a couple grade 8's and use a pry bar between them.
Hard to find one at the hardware store.Thats actually what I was gonna do. I need to find one or maybe just go get a grade 8 one for the front of the crank.
Mopar Performance Harmonic Balancer Bolts P5249557ABThats actually what I was gonna do. I need to find one or maybe just go get a grade 8 one for the front of the crank.
Choke rod, cut a slot in a 1/4” or 5/16” bolt. Put over rods and snug up a nut.
Perfect. Just slot the hole for 2 rods.I bet you could use a couple of these as well.View attachment 1715289691
Overkill but yes. LOLView attachment 1715289695
Choke rod dilemma helper?
Good morning from not as soggy as the rest of Ca
Local Weather from AccuWeather.com - Superior Accuracy™View attachment 1715289695
i was just reading that. I guess its the most feared one for tornadic weather in the spring time, followed by hotter than hell temps for the summer for the plains and midwestI just happened to flip past the Weather Channel yesterday when they were talking about the Southwest. The powers that be have "officially" decided that we are having an El Nino event. They didn't say which of the 3 documented varieties this is.
Yeah I failed to mention the difference in choke rod length. It worked it just didn't open to quite vertical. Easy fix. File 2 little notches in the rod, cut it in two between the notches. Use a little piece of soft tubing to extend the rod the same difference as base gasket thickness. Stake the tubing to the notches with a wire terminal crimper.Hey all. if you use a thick base gasket, the factory choke will not work any longer. Food for thought. The choke rod will be to short to function correctly.
