Stop in for a cup of coffee
I love that stuff ! Different colored noodles and onions and such ? ... But I need protein this morning, guess it will be eggs over easy and toast with Strawberry jelly this morning :color:
Yeah Mike. She also puts some broccoli and slices of pepperoni in it with Italian salad dressing. Yum!!
It is the programming I don't get. And I used to work on military aircraft avionics!
THE SERIES INTELLIGENT TEMPERATURE AND HUMIDITY CONTROL INSTRUMENT INSTRUCTIONS
1. overview
1.1 High-precision temperature and humidity sensors, and have adjusted digital filter function
1.2 The two alarm outputs, lower limit alarm or higher limit alarm mode can be chosen. Independent set the alarm sensitivity
1.3 Analog output will send (option), can be measured, transform the display value after in standard current, voltage form output for other equipment
2, TECHNICAL SPECIFICATIONS
2.1 Measuring resolution: temperature is 0.1℃, humidity is 0.1% RH
2.2 Measurement precision : temperature is 0.5℃, humidity is 3% RH
2.3 Display range: temperature is-30.0 ~75.0 ℃;
Humidity is a median 5 ~ 99.0% RH
2.4 Alarm output:
Two road relay output, Relay contact output: 250V AC 10A
2.5 Analog output:
2.5.1 4mA~20mA, 0mA~20mA DC current output, by setting options
2.5.2 Load capacity is less than 600Ω
2.6.4 Output resolution: 1/4000 F.S, error less than 0.3
★ Analog output for option function, only when buying choice, meters only with this function。
2.7 Power supply: AC power consumption less than 85 to 265V 3VA
2.8 Working environment: 0 ℃ ~ 60 ℃, humidity below 90% RH
2.9 Dimensions:
model Shape dimension Panel hole display
THE20 48×48×82 mm 45×45 mm 0.36 inch LED
THE70 72×72×75 mm 68×68 mm 0.56 inch LED
3 OPERATION
3.1 Configuration of the Instrument Panel
NAME EXPLAIN
②Temperature measurements display  Measurement condition, shows temperature measuring values
 In parameter condition, display parameters prompt
③Humidity measurements display  Measurement condition, display humidity measurements
 In parameter condition, numerical display parameters
①Alarm indicator  Measurement condition, alarm status display
OUT1: temperature alarm indicator light, OUT2: humidity alarm indicator
④ SET KEY
 Measurement condition, click the criterion to enter setting state
 In the set state, the display parameter symbol, click the changes to the same group the next parameters
⑤ SHIFT KEY
 In setting state, display setting value, mobile modify bits
⑥ REDUCE KEY  In setting state, display setting value, decrease the value
⑦ ADD KEYS
 In setting state, display setting value, increase parameter values
3.2 Parameter Settings that
Instrument arguments is divided into 2 groups. All the parameters by LCK parameter control
LCK(LCK)-- Parameters locking choice, each data by locking after may not be installed
LCK==00: All the parameters can be set up
LCK==10: Only alarm parameter group can Settings (group 1 parameters)
LCK==11: All parameters are not set (LCK except)
3.3 Alarm parameter group setting method
3.3.1 Click the key instrument enter setup state, instrument vista shows the 1 parameters of symbols, discharge shows that this parameter setting value
3.3.2 Use key can choose other parameters
3.3.3 Use through the modified bit, use key increase setting, use key reduce setting, the parameter is amended as need values
3.3.4 Press the key deposit modified parameters automatically forwarded to the next parameters. If the excellent-good。
3.3.5 Repeat 3.3.2 ~ 3.3.4 radar echoes captured, can install other parameters。
3.4 Function parameters group setting method
3.4.1 Press the key above three seconds don't loosen, enter setup state, instrument vista shows the 1 parameters of symbols, discharge shows that this parameter setting value
3.4.2 Use key can choose other parameters
3.4.3 Use key move modify a, use key increase setting, use key reduce setting, the parameter is amended as need values
3.4.4 Press the key deposit modified parameters automatically forwarded to the next parameters. If the parameter group last parameter, press key would turn to parameter group of the first parameter.
3.4.5 Repeat 3.3.2 ~ 3.3.4 radar echoes captured, can install other parameters
3.4.7 Exit setup: hold keys remain above three seconds don't loosen, will exit parameter Settings
★ If we cannot set, should check parameters and whether it is LCK lock
4、PARAMETERS LISTED
Group 1 parameters ★Alarm parameter group (click SET KEY enter)
NO. Dislay name use range explain
1 TY1 TY1 Temperature alarm way 0-4 5.1
2 AL1 AL1 Temperature alarm value -199~999 5.1
3 HY1 HY1 Temperature alarm back to the difference 0~999 5.1
4 TY2 TY2 Humidity alarm way 0-4 5.1
5 AL2 AL2 Humidity alarm value 0~999 5.1
6 HY2 HY2 Humidity alarm back to the difference 0~999 5.1
In group 2 parameters ★Function group (Press set key remain above three seconds into)
1 TSC TSC Temperature zero modifier -100~100 6.1
2 HSC HSC Humidity zero modifier -100~100 6.2
3 OPY OPY Analog output signal choice 0、1 5.2
4 oP oP Analog output type choice 0、1 5.2
5 OPL OPL Output limit -199~999 5.2
6 OPH OPH Output ceiling -199-999 5.2
7 LCK LCK Parameters locking level 0~999 3.2
5、Function and the corresponding parameter instructions
5.1 Alarm output
Each emergency alarm have three parameters for each set alarm value, choose alarm mode and set alarm back to poor..
5.1.4 Alarm way:0 : means limit alarm(Figure 1)
(can be used for cooling or dehumidification control)
1: lower limit alarm (Figure 2)
(can be used for heating or humidifying control)
2: shows the upper and lower limit alarm (alarm output), as shown in Figure 3
3: shows the upper-limit alarm action delay, when the measured value is greater than AL1 (AL2), the relay pull HY1-minute delay successor open (and the measured value must be less than AL1/AL2).
4: shows the lower limit alarm action delay, when the measurement is less than AL1 (AL2), the relay pull HY1-minute delay successor open (and the measured value must be greater than AL1/AL2).
5.2 ANALOG OUTPUT
The only for THE70, THE20 not have this option
5.2.1 OPY(OPY) ——Analog signal choice
Choose is 0: output signal for temperature
Choose 1: output signal for humidity
5.2.2 OP(OP) ——Analog output type
Choose is 0: output is the 4mA -20mA
Choose is 1: output is the 0mA -20mA
5.2.3 OPL(OPL)—— Analog output 4mA or 0mA value
5.2.4 OPH(OPH)——Analog output 20mA value
Ex. : temperature signals required analog output 4mA - 20mA, corresponding to 0-80.0 ℃,
Setup parameters OPY = 0 OPL = 0.0 OPH = 80.0
6、ADJUSTMENT
Adjustment can be reduced because sensors, lead by the error of measurement, and improve the system of measurement accuracy
6.1 TSC(TSC)——Temperature modifier
The display value = fixed before the temperature display value + TSC
6.2 HSC(HSC)——Humidity modifier。
The display value = fixed before the display value of humidity + HSC
6.3 FLR(FLR)——Digital filter value
With digital filtering methods to overcome the input signal wobble. User visual signals jitter of frequency and size selection of appropriate filtering constants, jitter serious when can increase set value★Tuning parameters factory has set good, generally do not need to change!
7、TERMINAL BLOCKS
7.1 AL1 output: temperature relay output(terminals: 7/8)
AL2 output: humidity relay output(terminals: 1/6)
7.2 Sensor wiring: please click sensor line color wiring
8、EXAMPLES OF APPLICATION
8.1 Heating, humidifying applications
Control requirements: temperature below 30 ℃ startup heating, more than 38 ℃ stop heating, Humidity under 60% RH startup humidifying, higher than 80% RH stop humidifying.
Temperature parameters: set to TY1 = 1, AL1 = 30.0,HY1 = 8.0
Humidity parameters: set to TY2 = 1,AL2 = 60.0,HY2 = 20.0
8.2 Heating, dehumidifying applications
Control requirements: temperature below 35℃ startup heating, more than 38.5℃ stop heating, Humidity above 85.5%RH startup dehumidification, below the 70%RH stop dehumidifier
Temperature parameters: set to TY1 = 1,AL1 = 35.0,HY1 = 3.5
Humidity parameters: set to TY2 = 0,AL2 = 85.5,HY2 = 15.5
8.3 Cooling and humidifying applications
Control requirements: higher temperatures than 39.5℃ startup cooling, below 35.0℃ stop cooling, Humidity below 60%RH startup humidifying, higher than 80%RH stop humidifying
Temperature parameters: set to TY1 = 0,AL1 = 39.5,HY1 = 4.5
8.4 Cooling dehumidifying applications
Control requirements: higher temperatures than 40.2℃ startup cooling, below the 37℃ stop cooling, Humidity above 80%RH startup dehumidification, less than 50.5%R stop dehumidifier.
Temperature parameters: set to TY1 = 0,AL1 = 40.2,HY1 = 3.2
Humidity parameters: set to TY2 = 0,AL2 = 80.0,HY2 = 29.5
I hate electronics. Not my strong suit. I'm outta here !!! Gotta take Mama to Sam's Club for her quarterly household consumables and food. Y'all have fun now, hear !!
The very same here :D love the stuff too :cheers:
I hear that, I have forgot more then I thought when I get to wiring something simple, the ol brain get confussed :D
We just made that run to Sam's Club Saturday :coffee2: You have a good one :D
This is really bugging me. I hate translated technical stuff, It never comes out right.
I personally like Cragar SS. But those would certainty be my second choice.
Cragars were my first choice but the more I looked at the small bolt ones the less I liked them. Too much wheel and not enough space between the rim and the center hub. Hoppy, those instructions might as well be written in Russian. Looks like a lot of specs and no directions how to hook it up. Well guys, off to work. See you on the flip side. tmm
This one [ame]http://aqutek.asia/downloads/th-20-manual.pdf[/ame]
Of course it is not in the instructions, when I go out to the shop I will see if it has a manufacturer, prob in Chinese with my luck. What do you think bring it to the local Chinese restaurant for translation?
My initial translation: toss in trash and order an Omron. LOL
Seriously, I'm usually pretty good at figuring out crappy directions. Right now I'm at work trying to get a gas fired, point of use water heater working. Seems to have gotten it's brain scrambled a bit. I'll try to decifer what you posted this evening if nobody says they got it before that...
Actually the wiring instructions were great, how do you mess up a schematic.
Thanks a lot guys it is appreciated. I should just go back to the temperature switches but no I wanted it to look high quality! Serves me right. I do like that hivac unit though, might be the way to go.
I have to run to Fastenal and see if they have 4 1/4" diameter pop rivets that work with a normal rivet gun for the firechickens window. Later.
I wonder if this is the same/almost the same unit.
[ame]http://www.fujielectric.com/products/instruments/library/manual/box/doc/TN2PYZDe-E.pdf[/ame]
That would be great zkx14 :color: I am getting bubble brained #-o if you know what I mean :D
Sooo, after 9 months of waiting for the estate to be settled, I am finally the proud owner of my uncles Harley Davidson! Just got out of the Secretary of State, all plated and insured and finally in my name!! Come on spring, where are Ya?? Enjoy the day all!!
Hey, I'm first today...
Grandma's improving. she is opening her eyes and can nod, can't talk yet...
I just got the call from my brother...
We lost grandma today...
We just visited her on Friday and she was doing better. She took a turn for the worse earlier today...
