Stop in for a cup of coffee
Get the proper camshaft, and then use a set of Rhoades lifters.
I've been using Rhoades lifters since the mid 80's.. It took a while for me to buy into them, but they are the real deal. Many other companies make the variable duration lifters, but the Rhoades work the best due to their patented groove for the oiling... They now have some with increased oiling capabilities, but the standard ones will work fine...
I had them in a 72 318 short block with 10.5 pistons. Then I put the top end of my 68 318 on them and it idled at 24" Hg with a stock 340 cam... But when it got above 80° F outside, I had trouble with it overheating due to the high compression.
So I found a cheap set of 360 heads with a fresh valve job and swapped them on with a stock 69 340 intake, and the vacuum was still pulling 22.5" Hg at idle. Still very strong pull with that much vacuum...
Vacuum is velocity, the higher the vacuum, the higher the velocity in the port. VELOCITY IS TORQUE!!!
You can also run a higher rated power valve in the carb and not kick it in for better mileage. I was still able to part accelerate on the highway at 13" of HG, with a 10.5" Hg power valve, so it didn't need to kick in under part throttle acceleration... I was getting 17.75 MPG with a 2.76 axle ratio...
Some people on the board have accused me that they are 'snake oil', but they work. I would recommend them..
Also, if you port the heads, go with making them as straight as possible to increase flow, but try not to open them up too much (area). The more area you get, the lower your vacuum/port velocity will be. Try to eliminate restriction but not open the port area too much.
Then don't over carb. A 600 or 650 CFM will work fine on a street engine...
I read elsewhere on the forum that RRR recommended Rhoades lifters a while back. I checked them out and they seem truly ingenious. I've seen your recommendation before, too.
I think I have the same cam as ScampMike has. It's a PurpleShaft. I have an LD4B and a 750 Carter AFB. I bought an old Holley 600 from BadSport in july. I've refurbished it and was planning on trying them both out to see which works best.
If I'm not planning on running the engine over 4,500 rpm much, I guess porting and bigger valves would be a wast of time, no?
The whole cam duration, LSA and ICL voo-doo, do I need to go there or should I just cc up my head and piston combo, post the data in my build thread and take the advice I get?
...or should I just cc up my head and piston combo, post the data in my build thread and take the advice I get?
That depends who the advice is from.... If it's from me, no. Lol
But then, I won't give advice if I don't know nuthin about it. Not true for everyone.
nice - just under an hour left for me.. chomping at the bit to get the weekend going and get out to the garage... almost left early..
No, I've been working. I just catch a few minutes here and there through the day. Actually about to wrap up for the week.
I have gotten to the point that I go to Summit first - nothing around here at all and, I don't know why but, Jegs doesn't do it for me.. of course I surf too, but Summit has been my go to for quite a while..
I wish I had a performance shop here, like Summit or Jegs... I hate ordering stuff locally, its never right!
I usually do that also, but I just got a large box full of parts this week from them. I didnt want to just order the oil pan gaskets and pay $9 for shipping, but I think Im going to have to bite the bullet and do it again.
I ordered a bunch of stuff from Summit recently and after I got it all realized I had forgotten one item - so I called them and got customer service on the phone.. talked them into free shipping on the one $40 item.. I leaned on my purchase history... you should pick up the phone! I explained it was my fault and if they couldn't do it for me I understood blah blah.. shoomoz and BS..
Yep, you guessed it.. Performance gasket set for the oil pan was a standard cork set...
I never thought about doing that. I will pick up the phone and call. It cant hurt!
I have to admit, my previous order was nearly $500 and I had made a simple mistake - one head gasket instead of two - but, like you said, it can't hurt.If you have any kind of history with them, they will probably hook you up. BTW - their hats are junk BUT, I asked when I placed that big order if they had any freebees going.. got me a free hat to wear out in the garage.:D
Hey folks.
One down - three to go. Kids, that is. The 4yo is asleep, the two 11yo:s are playing on their iPads on the couch and the 13yo is half a click away at her grandmother's hangin' with her cousin. I hope ...
