Stop in for a cup of coffee
I have no idea what I'm doing that has kept me from getting it. I thought for sure by now because I've been around so many people who were/ are positive. Yet I keep coming up negative. I got my results today from a test on Friday. Still negative. I don't know what to think.
I think I'm just lucky, because In the beginning I thought I'd probably be one who dies from it. It's really scary like a really bad dream that all this is happening.
I think most of us have thought similar. I am definitly a bit on edge as the numbers keep going up and the cases are getting closer.
I get temp tests several times a day from different places I go, haven't had any issue or symptoms yet, but if I do it's an automatic 14 days off, unless I bring in a negative test result,
I wonder if employers are going to back off of the 14 days since CDC changed their recommendation this week. I think it's 10, or 7 if tested now.
If I survive long enough to see the end of covid and regular life returns, I'm going to rave to make up for lost time. Rave like there's no tomorrow
I's that where you were supposed to go this year?
Very similar. I was going to go to tomorrowland and there's several similar ones in the USA. There's a really good one in Vegas. I've never been to Miami but there's Also a huge one there. Red rocks here in Colorado has been known for some good ones.
Morning!
12f this morning. A tad chilly.
Back to the truck today, see if i csn get sheet metal around pedals sorted out. I have a pair of pedal seals, but have to remove pedals off transmission to get them installed.
Dam cases spiked 2000 new overnight!:BangHead::BangHead::BangHead::BangHead:
Well come to find out, one of the rapid tests they use for Covid, is now under scrutiny because it also shows positives for both flu A and Flu B as well as Covid...
Lots of interest in them
Hey, meant to ask this, the plugs that going into the ignition boxes, those are the same regardless of slant, small block or RB right?
the plug in my w200 where this box I got from you is going is busted, was gonna score one from a junkyard but wasn’t sure if there was any differences.
Previous owner of the Polara when he converted just soldered wires directly to the box so I have no reference.
